Home > Puma (Tdci) > Welding on a TDCi what do I disconnect? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Just pull the negative (earth) lead from the battery. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
9th Aug 2018 8:09am |
Following the handbook instructions to disarm the BBUS first, if you have one fitted. Darren
9th Aug 2018 10:28am |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 |
I don't think Ozzie spec Defenders had that.
9th Aug 2018 1:30pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
As well as the negative, take the positive off too and check all switches are off.
You should then be good to go. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
9th Aug 2018 2:13pm |
Why? ^^ 80" 80" 86" 88" 90"
9th Aug 2018 2:39pm |
Just completely isolates everything that way.
Depends on what type of welding in question as well. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
9th Aug 2018 2:46pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 622 |
Key for safe welding is good ground connection close to the welding point and on the welded part. This will minimize current leakage through rest of the car. "Drobek" = The Small One - Discovery 2, "Blufรญnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
9th Aug 2018 2:55pm |
