Home > Puma (Tdci) > Welding on a TDCi what do I disconnect?
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
As the title said, I want to weld on my TDCi, what's the safest way without damaging the vital bits.
Post #722434 9th Aug 2018 7:58am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just pull the negative (earth) lead from the battery. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #722452 9th Aug 2018 9:09am
Following the handbook instructions to disarm the BBUS first, if you have one fitted. Darren
Post #722478 9th Aug 2018 11:28am
PAT303
I don't think Ozzie spec Defenders had that.
Post #722507 9th Aug 2018 2:30pm
As well as the negative, take the positive off too and check all switches are off.
You should then be good to go. WeWillWin🇬🇧🇺🇸
Post #722510 9th Aug 2018 3:13pm
ian series 1
Why? ^^ 80" 80" 86" 88" 90"
Post #722517 9th Aug 2018 3:39pm
Just completely isolates everything that way.
Depends on what type of welding in question as well. WeWillWin🇬🇧🇺🇸
Post #722518 9th Aug 2018 3:46pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Key for safe welding is good ground connection close to the welding point and on the welded part. This will minimize current leakage through rest of the car. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #722520 9th Aug 2018 3:55pm
