![]() | Home > Td5 > Defender TD5 cruise control.....confused! |
I’m guessing that question was aimed at me. I made the switch, no one sells one at the moment. See my build thread below for a couple of pics how I did it. Ray
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3019 ![]() ![]() |
Thanks for the link, but there’s 67 pages on that thread!
Can you tell me what page it’s on? Cheers. |
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
Digging up and old thread here...Do all TD5's support Cruise control ? Mine is a Jan 99' model. 1999 Defender TD5 110
I think it’s post 2001 when they changed the ECU.
But not 100% sure. I fitted the Nakatanenga kit to my 2005 TD5 Defender and it works fine. The kit costs just over £100 But for some reason it’s not listed on the UK site, only the German one. The instructions are in German but they sent me English ones on a PDF file. |
Thanks lightening. A bit more research required. 1999 Defender TD5 110
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
It should be an NNN ecu and not an MSB ecu. The defender has migrated, leaving the owner behind.
The cruise control has transformed long journeys in my 110. We recently drove to Scotland (a round trip of 860 miles) and it was great to set the speed at 65mph and then just steer. After slowing down you can just press the resume button.
I would say it’s the best accessory l have fitted. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
FWIW... I have an 2000 MY and would love cruise as well but alas.... Its not cruise but this little mod made long distance driving a tad more comfortable by undoing one of the throttle springs. Its easier on the right leg. ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I have modified mine as well, by drilling a new hole for the spring a bit further round, so reducing the tension.
[quote="lightning"]I have modified mine as well, by drilling a new hole for the spring a bit further round, so reducing the tension.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Bim Member Since: 09 Jun 2018 Location: Cambs Posts: 28 ![]() ![]() ![]() |
Would like to do the cc mod but will it work with Roamer overdrive also if using a speed healer is this switched on and off with the cruise control
TheLastMaverick Member Since: 16 Apr 2017 Location: Nottingham Posts: 10 ![]() ![]() ![]() |
It should work with the overdrive with the speed healer fitted, overdrive only normally affects CC in 5th gear, but the speed healer will allow full use of CC.
The CC should not interfere with the workings of the speed healer. Mike |
