Home > Puma (Tdci) > Injector Fuel Leak
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
Injector Fuel Leak
Evening all, jobs are never straight forward!! Had the tell tale oil around the top of the rocker on all 4 injectors, so had the injectors out and hey presto they were in a rough state. So 4 recon injectors from a reputable place, cleaned all the injector seats and put back in, new clamps, seals and stretch bolts. Injector learn and we were away. Unfortunately injector 1 has a fair pool of diesel around in the well of the rocker cover???? Any ideas, I can't see it leaking anywhere and the oil level hasn't risen?? It's also jogging/pulsing when you come off the accelerator. Very Happy
Post #720131 28th Jul 2018 8:51pm
zsd-puma
probably leaking out of the metal pipe to it or the plastic leak off pipes. You're supposed to replace all of them when you pull the injectors, but in reality most of the time you can get away with reusing them.
Try replacing the leak off pipe with a new one, and if that fails the metal pipe for that injector.
Post #720141 28th Jul 2018 11:12pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Check the little green leak off O ring which push in the top of the injectors,
They are easily damaged without noticing. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #720148 29th Jul 2018 6:24am
Deerfold
Thank you, I have replaced the O rings but I will get a piece of paper and see if I can see a leak, could well be the metal fuel pipe. I may get the leak off pipes for peace of mind.
Post #720170 29th Jul 2018 8:49am
zsd-puma
I found the green o-rings supplied with the 'transit parts' kits, were too fat and tore when you tried to push them in. So I refitted the original o-rings.
Post #720186 29th Jul 2018 11:01am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Censored , I've just bought that OE Ford kit to do mine. Is genuine the only way to go then?
Post #720204 29th Jul 2018 12:17pm
ian series 1
Genuine Ford parts are what you will get with Genuine Land Rover parts,
Only you will get a pretty green oval sticker, rather than a blue one! Laughing
Oh, and probably pay 30% more for the privilege Wink
The non genuine O rings are a waste of time, they are an odd size too, I can’t match them in either imperial, or metric? 80" 80" 86" 88" 90"
Post #720224 29th Jul 2018 1:20pm
Deerfold
Well, narrowed it down to injector 1 metal pipe not sealing properly. Grab a new one tomoz and we should be away!!
Post #720281 29th Jul 2018 5:30pm
zsd-puma
I got the non-genuine kit from Transit Parts. It was all good, except the o-rings. I don't think the complete leak off pipe kit was much from Land Rover though.
With the copper injector washers you're paying more than 30% markup! They're something crazy like £19 each plus VAT from Land Rover. Ford are about £8 each, Citroen (use the Puma in the Relay van) only want £7. But you can get them from any fuel injection place for £1 each or less. It pays to shop around.
The great thing with the Puma is it's in lots of vehicles, so if you want genuine you can shop around Ford (Transit, Ranger, Mondeo), Peugeot (Boxer), Citroen (Relay), Fiat (Ducato) and Land Rover dealers to find the cheapest.
Post #720373 29th Jul 2018 11:02pm
