Home > Puma (Tdci) > Battery and warranty |
I think the short answer is yes. I can't imagine LR considering a claim just because it won't power a non-LR accessory. Darren
23rd Jul 2018 11:49am |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 |
I think the POV from LR would be that the battery is for cranking the car and is suitable for that purpose so unlikely they would replace under warranty if being used outside of that.
23rd Jul 2018 12:16pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
That's what I was afraid of.
I'm not going back to the stone age of not having a fridge running 24/7 so I will probably have to got for that overdue dual battery setup I have been putting off. |
23rd Jul 2018 12:56pm |
Here you go - a little bit of inspiration:
http://www.defender2.net/forum/post714105.html#714105 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Jul 2018 1:06pm |
I did something similar...
Click image to enlarge When I say I, I mean the man at the garage |
23rd Jul 2018 1:26pm |
Oooh, nice, I like that one. I'll probably replace the main battery with a smaller one but could do something similar. |
23rd Jul 2018 2:43pm |
Ask your local dealer, they wont bother to check what it's powering they'll just put it on a tester and see if it passes. Tell them a couple of times it's been sluggish to crank.
If it fails the test they should replace it. If it passes, they'll just say your fridge is running it down. |
23rd Jul 2018 4:10pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Agree with ZSD - just "forget" to tell them about the fridge. Defender 90XS SW
24th Jul 2018 7:22am |
"Tester" I laugh. I while back I had to take a battery back to Halfords. It read 10.6V across the terminals after sirring in a crarger for 24h. Clearly a cell was cone. The fella put the battery in the "tester" and the tester spat out a print-out with a few tests it had done, including overall voltage of 10.6v and then bottom line in capital letters **** PASSED ****
Facepalm... I might try it with another dealer. My local is beyond useless. |
24th Jul 2018 8:00am |
