Home > Puma (Tdci) > Can't get the heater to blow cold
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Even with the control turned down to coldest the heater still blow hot.....and in this unusual weather ….well..!!
Would this be faulty control valve as mentioned in other posts?
Post #718686 20th Jul 2018 8:22am
familymad
Should blow ambient which isn’t cold right now but wouldn’t say it’s heated hot air. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #718692 20th Jul 2018 8:48am
Most probably.
Post #718694 20th Jul 2018 8:53am
Caterham
what I found recent was the cable on the valve wasn't shutting it completely.
pop the bonnet and see if you can shut the valve manually / see if it sorts the problem and if it does then you just need to adjust the length of the cable.
at that point perhaps you can let me know how Very Happy
mind you, you won't need to worry about that until winter Mr. Green
Post #718695 20th Jul 2018 8:54am
zsd-puma
yep, as above. Check the cable operation, if thats ok buy a new valve.
Post #718700 20th Jul 2018 10:00am
chipmunk
Thanks guys....will try that fix......when the rain stops..!! Shocked Shocked
BTW it's any weather, hot or cold so not ambient....it was heating my knees
Post #718706 20th Jul 2018 10:24am
chipmunk
PS. Only done 30k miles.....
Post #718709 20th Jul 2018 10:50am
zsd-puma
the valves aren't very good.
Post #718712 20th Jul 2018 11:08am
^^ and yet are very expensive!
Post #718718 20th Jul 2018 11:50am
hank
Post #718728 20th Jul 2018 12:18pm
chipmunk
Cheers Hank and all...… still raining....sods law.!
Post #718734 20th Jul 2018 12:29pm
zsd-puma
I wondered if they included the huge metal bracket in the box, just to justify the price.
Post #718745 20th Jul 2018 1:29pm
chipmunk
J....C almighty...……………… !!!!!
£103 for a piece of plastic......and a lot of unneeded metal.
Hoping that a Transit one would fit...……£135.... Sad Sad
Couldn't just have been a slipped cable....oh no..!
Post #718776 20th Jul 2018 4:41pm
Yes, they're roughly four times the price of the much more sophisticated thermostatic, electrically controlled valves used on Ford cars. Explain that if you can.
Post #718781 20th Jul 2018 4:53pm
zsd-puma
I would imagine not just making the metal bracket but also paying someone to fit it to the metal bracket shoves the price right up.
I think I paid about £80 from my dealer, it's why it's worth building up a rapport with them. Still expensive for what it is.
Post #718793 20th Jul 2018 5:58pm
