Home > Puma (Tdci) > FORScan OBDII scanner works on PUMA 2.4 TDCI
Page 1 of 5 12345>
4wd-junky
Following another members post about FORScan, I too have just successfully connected FORScan to my PUMA using a cheap usb adapter (ebay eBay Item No. 153070327324), Windows 10 laptop and FORSCan 2.3.16 BETA https://forscan.org/download.html
Screen shots attached. (I have deleted my VIN number from these)
Please note, so far I have only viewed settings and faults. I have not performed any resetting or learning functions, although the other member has confirmed that pump and pilot learning functions work. Very Happy
Post #718616 19th Jul 2018 8:08pm
zsd-puma
It probably does the engine side of things - thinking it's a Ford Transit.
The advantage with the Land Rover specific tools is you can also do the ABS and Security stuff. But then they are paid for.
Post #718636 19th Jul 2018 10:18pm
4wd-junky
Yes, it's a cheap solution that should help DIY Defender owners keep their 'transit' engines running Very Happy
Post #718641 19th Jul 2018 10:59pm
ampstp
Apart from being able to execute the service routines that are now assessable, one clear benefit of the forscan is being able to graph fuel pressure (desired) against fuel pressure (actual) thus checking the health of the entire low and high pressure system including rail sensor and VCV in my case over a 15 minute drive at various speeds and loads. Great free software! Obviously you can add many sensors to the graph CHT, fuel temperature e tc e tc to help with fault finding. My vehicle was simply overdue for a VIV clean and pump re-learn.
Post #718766 20th Jul 2018 5:08pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Another vote from me for ForScan.
Used it to do Pump Learn and Pilot Correction - talked me through the whole process giving me all the requirements to allow it to complete such as fuel temp and coolant temp.
Drives like a different vehicle Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #730429 21st Sep 2018 9:33pm
MK
Another + for Forscan. I could test and remove (so far) some stouborn DTCs. Pump and injector calibrations done. I could not do it neither with SDD nor Nanocom.
It also reads all injectors 16 digit codes which is nearly impossible unless you use a 10-20x handlens. Puma 110" SW
Post #751977 17th Jan 2019 9:48pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
My ebay speshal arrived this morning, will have a look over the weekend with FORScan Thumbs Up
Post #752014 17th Jan 2019 11:10pm
FORScan.....
sorry, sounds too much like ForeSkin Whistle Laughing Laughing
Post #752227 18th Jan 2019 9:55pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Mine has only the ECU and the 10AS. No ABS, ETC or anything else. I'd like to try the FORscan in addition to the Nanocom.
Post #752415 19th Jan 2019 5:51pm
MK
The whole thing is to get a obd2 plug that works. I reckon it needs to be Elm327 with HS capability. A generic elm327 wont work. Puma 110" SW
Post #752416 19th Jan 2019 5:56pm
Badger110
Post #752447 19th Jan 2019 7:21pm
MK
It does.
Now I would like to know if anyone got a bluetooth unit that in fact works. Puma 110" SW
Post #752450 19th Jan 2019 7:32pm
Tomotomo
I read this thread and bought a lead from the link. It arrived today and I can confirm it works fine.
I have a question to the people that are more familiar with forscan.
Is there a way of checking if the injectors have been
Set up correctly or do you have to do the re learn ?
Tom
Post #752480 19th Jan 2019 8:49pm
dgardel
Italy
Same for my car..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #752481 19th Jan 2019 8:50pm
MK
Tom
 Puma 110" SW
Post #752493 19th Jan 2019 9:44pm
Page 1 of 5 12345>
