Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 3 of 33 <123 4 ... 313233>
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
1, 2012
2, 2.2
3, Y
4, 107 000 kms Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #717451 13th Jul 2018 7:26am
agentmulder
Kuwait
1, 2008
2, 2.4
3, Y
4, 70,000mi
Thumbs Up Solved the bowel problem, working on the consonants...
Post #717488 13th Jul 2018 11:24am
Martin
Site Admin
1. 2014
2. 2.2
3. Y
4. 23,000 miles  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #717490 13th Jul 2018 11:33am
DSC-off
Thanks to everyone that's responded so far, we now have info for 37 vehicles.
Some things are already starting to show a pattern.
More responses will improve the accuracy of any findings, please keep them coming. Thumbs Up
A few things that are standing out from our small sample:
Only 3 vehicles have reported the original shaft lasting longer than 100,000 miles. All early 2.4's from 2007 to 2009.
2.4's 66% of shafts have failed or have been changed.
Failure is generally between 50,000 and 90,000 miles.
2.2's 44% of shafts have failed or have been changed.
Failure is generally between 25,000 and 65,000 miles - so far.
Many will be newer low mileage vehicles, but they are definitely failing sooner.
Post #717584 13th Jul 2018 10:30pm
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
1. 2010
2. 2.4
3. N
4. Shaft replaced at 91,000km's. It didnt fail, but was very close to looking at the wear on the splines. Replaced with Ashcroft kit
Post #717586 13th Jul 2018 11:07pm
Pickles
2013
2.2
yes
45000klms.....very respectfully driven (which obviously makes no difference to this issue)
The only "warning" we received was that about 3-4 klms before we lost all drive, we heard a loud "click" from somewhere, which we thought we'd check out when we got home, but we never got there. The "click" was obviously one or more of the splines breaking away, prior to total failure a few klms later.
Fitting the new shaft never made any noticeable difference to driveline slack that we had before failure.
Pickles.
Post #717587 13th Jul 2018 11:30pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
2015 (MY16)
2.2
Original
23,000
Well done DSC-off Thumbs Up
Post #717633 14th Jul 2018 9:51am
2. 2.2
3. Y
4. 39K
It's clunky though, so will be changed in the not too distant future. Darren
Post #717709 14th Jul 2018 6:30pm
Bluest
Re: Output shaft failure, Forum Survey
1. 2007
2, 2.4
3, is the Defender still running with the original output shaft? Yes
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. 82,000 on original shaft. 2007 110 TDCi Station Wagon XS
Post #717714 14th Jul 2018 7:06pm
toetankh
Netherlands 2007 Defender 110 Puma 2.4 SW Stornoway Grey
1, 2007 (vehicle year of manufacture)
2, 2.4 (engine type 2.4 or 2.2)
3, N (is the Defender still running with the original output shaft? (Y/N))
4, 110.000 km (no failure!) (vehicle milage at first shaft failure, or current milage on the original shaft if still running).
If the shaft has previously failed, please answer 5 & 6.
5, Y (Has an Ashcroft modified part has been fitted? (Y/N))
Because I had the t-box out to inspect the shaft, I replaced with the Ashcroft kit (not necessary, see photo attached)
When the shaft came out, it was bone-dry and covered in red dust. Looked ok, no play in the coupling.
Has anyone replaced the shaft on the garage floor? What a pig of a job..... Smile
Post #717846 15th Jul 2018 3:18pm
Caterham
on shaft number 4 now.
Ans,
1 MY11 (actual Nov'11) - sorry that should be (Nov'10),
2 2.4
3 N
4 25k
5 N
6 60k
Thumbs Up
Post #717852 15th Jul 2018 4:13pm
Grenadier
1, 2011
2, engine type 2.4
3, Being changed as we speak
4, 60,000
5, Ashcroft modified part Not allowed, being redone by LR Dealer Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #717871 15th Jul 2018 5:13pm
DSC-off
I'm aware that our 'sample size' is still low and it is far too early for conclusions, but patterns are emerging.
Any suggestions of things to look for or known trends in the failures, please mention it.
After the latest replies, and looking at the age of the vehicles, 3 typical distribution patterns are emerging for manufacturing years and failure mileage.
Most replies with failures of 2009 to 2011 vehicles happened between 50,000 and 70,000 miles.
Early failures can happen between 25,000 and 30,000 miles, starting with 2011 vehicles through to 2015.
Worryingly, this failure seems to repeat itself, 2 members report multiple failures at this frequency.
Then the 'frequency' of the chart stands out.
Different failure groups at 25-30K, 50-60K and 75-90K. That could be a step too far to make a theory yet.
What I would like is feedback on the Ashcroft shafts, how long have they lasted?
It would be good to prove one way or the other if they do last longer than the original.
Also the multiple failures, if you've had 2 or more please send the mileage of each failure.
Repeated failure at the same or similar miles would be very useful if we can prove it happens.
Cheers.
Post #717959 15th Jul 2018 11:09pm
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
MY2007
2.4
original shaft
110,000km
Post #718019 16th Jul 2018 12:39pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
1. 2010
2. 2.4
3. N
4. 19000 miles
Post #718024 16th Jul 2018 12:59pm
