Home > Puma (Tdci) > The strip down begins, TDCI head-gasket??
Page 4 of 8 <12345678>
Thumbs Up $W33T $0U7H3RN $UG4R
Post #716096 4th Jul 2018 2:04pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Picked up the head this afternoon,
It’s had a 10 thou skim, and all looking nice,clean and shiny.
Putting it all back together tomorrow, so fingers crossed Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #716464 6th Jul 2018 5:38pm
Stacey007
Very Happy
Keep us updated, hope you sort it.
Post #716484 6th Jul 2018 7:33pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
ian series 1 wrote:
Daniel
Number 4 was the cylinder with an odd combustion pattern, if any water was entering the bores, I’m 99% this was the one?
The bore looks good, as does the top face of the block,
Obviously it’s only a visual check though.
I can only hope now, that what I’ve done will be enough to cure the problem? Rolling Eyes
Scott,
It’s just nuts, bolts and chains assembled in an specific order... Laughing Thumbs Up
I’ve already been looking at its replacement... Mr. Green
Hi Ian,
Just abit of thought, have looked at the full length of the liner on Cylinder 4? .....Well what's visible as I have had cracked liners on Gen sets (albeit alot bigger capacity)
Andy Thumbs Up Working towards Carry on camping!
Post #716493 6th Jul 2018 7:56pm
ian series 1
Hi Andy
I’ve had a good look at the block and bores, I’ve even had my magnifying glass out! , like you say (as far as you can see)
As you well know, the only way to be 100% is to pressure test the block,
But I really don’t want to go down that road yet! Rolling Eyes
To be honest, if it was that?
I can get a short recon unit for £1100, which would be the way to go,
I wouldn’t mess about with mine.
The guys who did the head said they would be very supprised if the block was at fault,
They said the only issues they have with them, is if it’s crank related.
I think I’ve done all I can for now, I’m replacing the pump and thermostat just so I can say it’s been done,
I will also back flush the matrix, block, and rad.
Fingers crossed Thumbs Up
Just incase anyone needs any work done, I can thoroughly recommend these guys,
Their workmanship is spot on, and the workshop is on another level. Bow down Bow down
http://www.hthoward.co.uk/
Post #716505 6th Jul 2018 8:38pm
MK
Interesting thread.
Did you find out if these heads can be skimmed further than what you have done?
thanks Puma 110" SW
Post #716526 6th Jul 2018 11:28pm
I notice on their website they say they only take work from trade customers, not private.
Post #716527 6th Jul 2018 11:34pm
Likeomg
Sounds exactly the same as when mine went a few months back...
unfortunately i had to go back to work so its only done the 300 miles or so back from alive to home... have some pics i can upload when i get a chance.
Post #716534 7th Jul 2018 5:21am
ian series 1
Today I put the TDCI back together.....
Headgasket on, this is the 3 hole gasket, which is the thickest you can get.
The marker holes are above where the high pressure pump is.
Nice clean skimmed head....
Head on, full set of new bolts, all 18 are single use on the TDCI.
Next, making sure every thing is clean, a squirt of oil here and there, and drop the cleaned cams in place,
Insert timing pins back in the location holes.
Next, fit the rockers, using new bolts on the carrier frame.
Time to fit the tensioner, cam sprockets, then the chain and guides,
Using the gold links to line up with the arrows on the sprockets, the fuel pump sprocket has a recessed mark to line up the chain.
The tension is held back off the chain until the pin is pulled out.
Always leave the cam sprockets, and pump sprocket bolts loose, before pulling the tensioner pin,
This allows the sprockets to move back slightly to lose the slack.
If you don’t, this is what can cause the chains to jump a tooth.
Front cover on, oil seal in, and starting to look like an engine again. Very Happy
The Puma carries Possibly the longest aux drive belt I’ve ever seen, other than on a Scania!
Oil and filter change and all done, considering it’s been stood for a week with the fuel rail and lines off,
It started quite willingly, I let it sit for half an hour on tickover, while I kept an eye on the water.
A quick run around the block, pulled over to look under the bonnet and it seems ok, apart from the Censored front crank seal was weeping! Big Cry
So I returned home to have a propper look, it’s Odd for a genuine Ford one to weep? I took it back out, and it appears to be the timing chain cover?
Stupidly, if I do these at work I always get a genuine seal, and cover.
Guess who thought he would save himself a few quid and brought a genuine seal, and non genuine cover,
The pressing isn’t that clever around the seal, and it’s pulling it away to one side. Big Cry
I will take it off tomorrow, and get a genuine Ford cover on Monday.
Hopefully that should be it?? Thumbs Up
Regarding the skimming, I’m not sure how far you can go on the TDCI?
The chap who do it, did say 10 thou was quite deep, and they wouldn’t go much more than that. Wink 80" 80" 86" 88" 90"
Post #716620 7th Jul 2018 7:36pm
keith
Ian
Thanks for an awesome detailed strip down and rebuild Thumbs Up
Keith
Post #716627 7th Jul 2018 8:06pm
Andy80
Good work Ian, so after a drive round the block .....Are you still thinking to sell?
Post #716629 7th Jul 2018 8:08pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Glad to see its back up and running. Hope it's cured the issue.
Cracking write up Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #716631 7th Jul 2018 8:13pm
williamthedog
Good write up. Think I'll go back to a push bike now.... It's easier to work on. Seriously top notch rebuild Thumbs Up
Post #716633 7th Jul 2018 8:39pm
ian series 1
Cheers guys, Thumbs Up
I don’t think anything like this has been covered on the forum?
So it’s always good to have some sort of record.
I could have gone into so much more detail, but the thread would have ended up like a Haynes manual! Laughing
Plus I just don’t have the time...Rolling Eyes
Andy, I’m really not sure what to do with it?
I had a mint low mileage TD5 Disco metropolis before this, the H/G went in that, I did it, and sold it.
I think this one might go the same way?
Not sure yet ?🤔 80" 80" 86" 88" 90"
Post #716634 7th Jul 2018 8:55pm
ian series 1
Out at 6.30 this morning before it got too hot!
Stripped out front cover again.
Found the culprit! Censored
The cover had a slight dish on the lip to one side, which was pulling the seal to one side, not worth trying to straighten it,
Cheap crappy parts, never worth the hassle Big Cry
I will order new genuine Ford cover, and another seal tomorrow,
Plus the 3 crankshaft pulley bolts, as they are only supposed to be tightened 3 times.
Don’t want to be breaking one of them off in the crank!! Thud 80" 80" 86" 88" 90"
Post #716660 8th Jul 2018 7:07am
