Home > Puma (Tdci) > The strip down begins, TDCI head-gasket??
Page 1 of 8 12345678>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I finally got cracking tonight to find out what the hell happend to my 90 over the weekend?
All signs indicate to head gasket, no external coolant leaks, no water in the oil, no oil in the water,
Heater works fine, so pump is ok, but looses 3-4 ltrs of water over 5 miles, then overheats.
No visible vapour from exhaust.
I did whack a load of K-seal through it when we were stranded, and particles of that are visible when I pulled the exhaust manifold and turbo off.
The Puma engine in a Defender is a bit of a lash up to say the least,
It’s shoe horned in there, which doesn’t make it a pleasurable job!
I’m now actualy thinking if it will be easier long term to take it out,
Sort the head out, then refit it?
I think it would be wise to get the head pressure tested, it did get cooked a few times. Big Cry
I’m finding it tricky finding out if TDCI heads can be skimmed?
Anyone done one?? 🤔
I will also replace the cam chain, camshaft, crank and pump sprockets while I’m in there.
I will keep this updated, as there is very little info regarding H/G failure on a 2.4 TDCI?
First few pictures....
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #714591 26th Jun 2018 9:55pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Good luck mate! Hope it’s not too expensive Shocked
Stephen.
Post #714592 26th Jun 2018 10:00pm
ian series 1
Too late Stephen! 💸💸 Shocked 80" 80" 86" 88" 90"
Post #714596 26th Jun 2018 10:08pm
zsd-puma
It's just as bad in the Transit, and there's actually more access on a Defender. I think the Puma was actually designed for the Mk3 Mondeo for transverse mounting. Mounted longitudinally in a Transit all the coolant hoses chaff and eventually they spit their coolant out.
Post #714630 26th Jun 2018 11:58pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
I see you got one snapped stud on the exhaust pipe Evil or Very Mad
Post #714635 27th Jun 2018 5:51am
ian series 1
More access in a Defender,
You having a laugh?
You must be working on a different Defender to mine?
I look after a small fleet of Transits for a company next door, ranging from 2008-2017 they are simple to work on,
From cam chains, to egr valves, replacing them is simple, they are all on big mileage and don’t give much trouble,
Certainly never had hose issues?
The Engine in Defender form is a very different beast, take the aircon/alternator mount on the right hand side,
What a Censored Censored !!
The daft alloy plate across the cam chain cover, which you have to strip 90% of the engine just to remove that!
Not to mention the snake pit of ill routed hoses and fuel pipes..
I could go on.
Give me the engine in Transit form, in a Transit any day.... 80" 80" 86" 88" 90"
Post #714637 27th Jun 2018 6:21am
ian series 1
You will always get one!
I will get that with the drill. Thumbs Up 80" 80" 86" 88" 90"
Post #714640 27th Jun 2018 6:31am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Good to see that you continue to boldly go where no man has gone before. (Hope you get back OK!) Thumbs Up
Sorry to have missed you at Anglesey.
Cheers, John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #714652 27th Jun 2018 8:02am
ian series 1
Sounds like you had a good trip John,
We were planning on driving up, but time was not on our side Rolling Eyes
Hope you got yours sorted Thumbs Up
Ian 80" 80" 86" 88" 90"
Post #714656 27th Jun 2018 8:28am
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hola Ian, antes de ir a lo mas dificil, mira el enfriador de gases de escape que esta enkla parte posteriior del motor !!!!
Suerte con el destripe.
Post #714677 27th Jun 2018 10:14am
ian series 1
Hola
sí, voy a mirar el mío, gracias por su mensaje Thumbs Up 80" 80" 86" 88" 90"
Post #714679 27th Jun 2018 10:23am
hornet
Re: The strip down begins.
Anyone done one?? 🤔
I had to take the same decision a few weeks ago. I went for a new head. If you do not see visable defects, there might be a chance of not detecting a crack when pressure-testing, even in hot water.
My symptoms were the same, but did not loose these amounts of water!
Post #714692 27th Jun 2018 11:26am
I once had a SAAB 99 with very similar symptoms which turned out to be due to a crack in the exhaust manifold, which was water-jacketed. The crack, which was entirely internal to the manifold and visible only by looking into one of the exhaust passages, allowed coolant to leak directly into the outgoing hot exhaust gasses and out of the tailpipe. It lost water at a starling rate but with absolutely no visible sign of a leak anywhere.
Whilst this clearly cannot happen on the Puma engine, it did make me wonder if it would be possible for an internal leak in the EGR cooler to cause a generally similar effect. i.e., coolant being lost directly into either the inlet or exhaust system and then being expelled through the engine and exhaust.
Post #714716 27th Jun 2018 12:54pm
ian series 1
I’m removing it tonight to pressurise it, so we will see?
Just been chatting to my mate in the parts dept at Ford, the cooler is a cool £400 and that’s with 25% discount!
In some ways I’m hoping it’s that, but on the other hand I could without it... Shocked
They did say they sell more coolers than head gaskets, but we are talking only 1 or 2 every 6 months or so.
Big thanks to Fernando who has sent some very useful pm’s on the subject Thumbs Up 80" 80" 86" 88" 90"
Post #714725 27th Jun 2018 1:07pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Just a thought, dunno if that's actually doable, maybe you could have blocked the EGR pipe at the exhaust manifold (i.e. before the cooler) and change the hoses to bypass the EGR cooler entirely? That would have lit up the MIL (but I guess it's the least of your concerns at this point) and could confirm if the cooler is faulty/leaking coolant.
But it's probably too late for that now. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #714759 27th Jun 2018 2:18pm
