![]() | Home > In Car Electronics > Combined key fob question |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 ![]() ![]() ![]() |
I've purchased a combined key fob off fleaBay with the intention of getting it programmed to the 10AS unit
This is similar to the key I've bought: - ![]() Click image to enlarge Should there be a transponder chip in gap in the fob marked by the red box above as per the one shown in the red box below: - ![]() Click image to enlarge Hope that makes sense ![]() Any advice on this issue welcome ![]() Cheers Jason |
After further research (i.e. looking inside my existing plip), it seems that you don't need a transponder chip.
However it looks like the blank blades for the all in one fobs are the mirror image to the Defender key: - ![]() Click image to enlarge As such it's no use! ![]() Further thinking and cunning plan required... |
Get your original key copied to a new blank then set about it with a grinder and fashion it into the same shape as the supplied one and then fit that in the fob
That's a great idea
![]() Cheers |
Think I may have found a solution: -
Buy one of these transponder non central locking type key blanks off eBay for £4ish: - ![]() Click image to enlarge Pull the blade out of it and note it's similar to the one that came out of the Freelander/Disco 2 combined key/fob: - ![]() Click image to enlarge just need to drive out the pin and transplant the plastic cover and pin over to the Defender blade. ![]() Click image to enlarge May need to fettle it a bit but should be ok. Will do a full write up once I've got it cranking the engine. |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
Yes that's another option
![]() Hoping that I won't need to fettle this one too much ![]() |
Bit late on this so sorry for resurrecting an old thread.
Recently purchased a Gap IID BT diagnostic tool which is able to reprogram keys. Tried to pair the Valeo combined key with the Defender but no joy. Tried a standard Lucas 17TN fob I bought off eBay for £5 and that paired no problem. I'm still researching and if I find anything, will report back. Jason Discovery 4 - Aintree Green Freelander 2 TD4 SE Automatic - Tonga Green Defender XS - Tonga Green - Gone Now Freelander 1 Td4 ES Manual - Epsom Green - Gone Now Freelander 1 Td4 Kalahari SE - Epsom Green - Gone Now Freelander 1 XEi - Epsom Green - Gone Now www.greenlandrover.uk |
Why not just get the key and programmer from here. I’ve seen a few good reports of the company but never used them myself.
http://remotekey.co.uk/land-rover/defender-2/ Ray My build thread http://www.defender2.net/forum/topic17615.html |
Hi Ray,
Did consider that initially but I'd read that the Valeo Freelander 1/Disco 2 combined key was essentially the same thing as the Lucas TN17 fob. I wanted to see if it could be done as then it would be a good money saving solution that folks on here could take advantage of ![]() It seems that the Valeo fob operates differently to the Lucas one though ![]() The Gap IID tool was bought for other reasons, the ability to program keys was a bonus so I took advantage of it to try and program the Valeo combined key. When that didn't work, I was able to program a Lucas fob so now I have 2 (when I bought the vehicle it only had 1). Cheers, Jason Discovery 4 - Aintree Green Freelander 2 TD4 SE Automatic - Tonga Green Defender XS - Tonga Green - Gone Now Freelander 1 Td4 ES Manual - Epsom Green - Gone Now Freelander 1 Td4 Kalahari SE - Epsom Green - Gone Now Freelander 1 XEi - Epsom Green - Gone Now www.greenlandrover.uk |
