Home > In Car Electronics > Combined key fob question
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
I've purchased a combined key fob off fleaBay with the intention of getting it programmed to the 10AS unit
This is similar to the key I've bought: -
Should there be a transponder chip in gap in the fob marked by the red box above as per the one shown in the red box below: -
Hope that makes sense Question
Any advice on this issue welcome Thumbs Up
Jason
Post #637513 14th Jul 2017 5:29pm
greenlandrover
After further research (i.e. looking inside my existing plip), it seems that you don't need a transponder chip.
However it looks like the blank blades for the all in one fobs are the mirror image to the Defender key: -
As such it's no use! Embarassed
Further thinking and cunning plan required...
Post #637647 15th Jul 2017 3:12pm
JWL
Get your original key copied to a new blank then set about it with a grinder and fashion it into the same shape as the supplied one and then fit that in the fob Thumbs Up
Post #637727 15th Jul 2017 10:07pm
greenlandrover
That's a great idea Thumbs Up I'll give it a go.
Post #637733 15th Jul 2017 10:20pm
greenlandrover
Think I may have found a solution: -
Buy one of these transponder non central locking type key blanks off eBay for �4ish: -
Pull the blade out of it and note it's similar to the one that came out of the Freelander/Disco 2 combined key/fob: -
just need to drive out the pin and transplant the plastic cover and pin over to the Defender blade.
May need to fettle it a bit but should be ok. Will do a full write up once I've got it cranking the engine.
Post #638493 19th Jul 2017 7:23pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
could you not just buy and blank and ask the local key cutter to grind and drill a hole for you?
Post #638494 19th Jul 2017 7:26pm
greenlandrover
Yes that's another option Thumbs Up
Hoping that I won't need to fettle this one too much Very Happy
Post #638495 19th Jul 2017 7:34pm
hank
Following on from your response to my post (thanks!)
I have been using a "transponder non central locking type key blank off eBay" that I had cut for months.
I've ordered a combined key/fob so once that arrives I will have the basic key and blade elements sorted.
Have you had any joy programming the electrics/button/transponder to operate?
Post #644626 17th Aug 2017 9:15am
greenlandrover
Bit late on this so sorry for resurrecting an old thread.
Recently purchased a Gap IID BT diagnostic tool which is able to reprogram keys.
Tried to pair the Valeo combined key with the Defender but no joy.
Tried a standard Lucas 17TN fob I bought off eBay for £5 and that paired no problem.
I'm still researching and if I find anything, will report back.
Jason Discovery 4 - Aintree Green
Freelander 2 TD4 SE Automatic - Tonga Green
Defender XS - Tonga Green - Gone Now
Freelander 1 Td4 ES Manual - Epsom Green - Gone Now
Freelander 1 Td4 Kalahari SE - Epsom Green - Gone Now
Freelander 1 XEi - Epsom Green - Gone Now
www.greenlandrover.uk
Post #715330 30th Jun 2018 4:32pm
mk1collector
Why not just get the key and programmer from here. I’ve seen a few good reports of the company but never used them myself.
http://remotekey.co.uk/land-rover/defender-2/ Ray
My build thread
Post #715336 30th Jun 2018 5:01pm
greenlandrover
Hi Ray,
Did consider that initially but I'd read that the Valeo Freelander 1/Disco 2 combined key was essentially the same thing as the Lucas TN17 fob.
I wanted to see if it could be done as then it would be a good money saving solution that folks on here could take advantage of Thumbs Up
It seems that the Valeo fob operates differently to the Lucas one though Big Cry
The Gap IID tool was bought for other reasons, the ability to program keys was a bonus so I took advantage of it to try and program the Valeo combined key. When that didn't work, I was able to program a Lucas fob so now I have 2 (when I bought the vehicle it only had 1).
Cheers,
Post #715502 1st Jul 2018 4:40pm
