![]() | Home > Series Land Rovers > Series One 2 litre Oil light Glowing |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Hello, Small's Series one has a two litre spread bore engine and the other day the oil warning light came on.
We have had the switch changed and it ran fine with no warning light. This morning the light is on again. The oil level is fine with no signs of excessive consumption. Any ideas or suggestions much appreciated Regards Swine 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
As Andy pointed out, I would get it checked with a gauge.
Might be a faulty switch, but better to check properly just incase ![]() Wanted, Forward Control Anything considered. |
Just out of interest, what oil are you using?
20w/50? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Hello Ian
Swine is way for the day so it is up to me at the moment. I am using 20/50 oil Regards Small 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Hello All
Thanks for your help as I had become a little confused as Swine was away. It appears that the wire to the pressure switch was a little chaffed and and was intermittently shorting against the engine hence the on/off oil light. Bit of tape from Swine's box and all sorted ![]() ![]() He will be proud of me . ![]() Thanks all 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
![]() Glad your sorted ![]() Wanted, Forward Control Anything considered. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
