![]() | Home > Series Land Rovers > Weight of a Series 2a Hard Top upper tailgate/cat flap |
EWG Member Since: 20 Sep 2015 Location: Betws y Coed, North Wales Posts: 102 ![]() ![]() ![]() |
The locking mechanism of the upper tailgate or cat flap of my 1962 Series 2a Hard Top is broken so I'm investigating supporting it with telescopic gas struts.
What I don't know is how much the cat flap/upper tailgate weighs. I've looked all over the 'net and the scant information I've read suggests around 62 lbs or 30 kilos. Is this correct? If anybody knows I'd be very grateful for the information. Thank you. |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
I used one for a while with no stays and it was not that heavy to hold above my head. It would be nearer 15kg than 30kg. 1995 Defender 110 CSW
1971 SIIA Lightweight |
Thank you for your replies.
I'm going to assume 15 kilos and add 10% for "belt and braces", |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
When I did my S1 flap, I used the kind of strut that allows you to bleed off some of the gas to depressurise the strut. When I initially fitted them the flap would open with such vigour that I was concerned that if SWMBO (who is fairly slight) opened it she'd be flung over the garden wall! By bleeding some gas out of the struts it was possible to set them to the perfect lift.
I am not sure where you intend to get your struts, but I always use and have always had excellent service from https://strutsdirect.metrol.com/ |
Thank you for your reply.
A firm called SGS was recommended to me and I have given them all the information I can including photographs. Your recommendation of Struts direct is much appreciated. |
