Home > Series Land Rovers > Weight of a Series 2a Hard Top upper tailgate/cat flap
EWG
United Kingdom 2002 Defender 110 Td5 PU Alveston Red
The locking mechanism of the upper tailgate or cat flap of my 1962 Series 2a Hard Top is broken so I'm investigating supporting it with telescopic gas struts.
What I don't know is how much the cat flap/upper tailgate weighs.
I've looked all over the 'net and the scant information I've read suggests around 62 lbs or 30 kilos.
Is this correct?
If anybody knows I'd be very grateful for the information.
Thank you.
Post #714612 26th Jun 2018 10:53pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
I used one for a while with no stays and it was not that heavy to hold above my head. It would be nearer 15kg than 30kg. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #714672 27th Jun 2018 9:57am
No way is it as heavy as 62lbs!
When I converted my S1 catflap to gas struts all I did was measure the force needed to hold it open with one of those cheapo luggage scales that are widely available and use that as the basis, unfortunately I can't remember what the result was. That is a more useful measurement than the overall weight anyway since the struts only support a proportion of the weight (the hinges support the rest).
If you are really concerned I do have a S2 catflap stashed away which I could weigh.
Post #714684 27th Jun 2018 10:54am
EWG
Thank you for your replies.
I'm going to assume 15 kilos and add 10% for "belt and braces",
Post #714710 27th Jun 2018 12:32pm
When I did my S1 flap, I used the kind of strut that allows you to bleed off some of the gas to depressurise the strut. When I initially fitted them the flap would open with such vigour that I was concerned that if SWMBO (who is fairly slight) opened it she'd be flung over the garden wall! By bleeding some gas out of the struts it was possible to set them to the perfect lift.
I am not sure where you intend to get your struts, but I always use and have always had excellent service from https://strutsdirect.metrol.com/
Post #714714 27th Jun 2018 12:42pm
EWG
Thank you for your reply.
A firm called SGS was recommended to me and I have given them all the information I can including photographs.
Your recommendation of Struts direct is much appreciated.
Post #714753 27th Jun 2018 2:09pm
