![]() | Home > Wheels & Tyres > Tyre Pressures |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
I would go for 28 in the front and 36 in the rear.
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
I would Go a bit higher.
36 in the front 40 in the back I drive a 110 a defender from 1984 pretending to be a puma with a touch of Range Rover |
manual says
![]() Click image to enlarge but 48 in the back will involve a trip to the dentist to replace your fillings. I use 30/38 for long motorway journeys but drop down occasionaly for a comfier ride. go lower and the handling and fuel consumption can suffer Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
I don't understand why the factory specs call for a higher pressure in the rear. My 110 is heavier in the front most of the time, with a full tank of diesel I've got a jack that will lift the back but not the front.
I don't really understand the manual. My 110 is heavier at the front than the back most of the time.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Perhaps landrover just want to sell you shock absorbers and suspension bushes 😳 |
