Home > Off Topic > My RRC project |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4790 |
1990 was the first year with ABS. The year that mine is
I will get to the bottom of it, just a matter of time Won't be taking the bulb out procta - it will fail it's MOT for sure 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Jun 2018 6:39am |
I've checked everything there is to check. There aren't any fault codes stored on the ECU. Strangely enough when you check the fault codes you don't need to remove the green ABS warning light relay to see the codes. However, changing the relay hasn't made a difference 2002 90 Td5 Station Wagon
13th Jun 2018 5:31pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
I thought i may of been able to help with another ECU, but the RRC i know of is well before 1990
Could you not call a vehicle electrician in, a mate of mine had a problem like yours and he fixed it Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
13th Jun 2018 8:43pm |
Thanks for the offer Clayton. I'm fairly certain it isn't an electrical fault - more of a component fault (relay or ECU fault.)
Going to try bridging relays tomorrow to make sure there are no feed backs to the ECU through the relays. I don't think the ECU is exiting diagnostic mode 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Jun 2018 10:14pm |
MOT booked
Found the problem with the ABS system. As I suspected it wasn't exiting diagnostic mode. All 4 wheel sensors had moved away from the exciter rings. As non of the sensors were triggering then there was no fault code - even if one sensor had been close enough then I would have seen fault codes for air gap for the other three. Anyway, all 4 sensors lightly tapped home with a small hammer and drift and the light went off as soon as I reached 4mph. RESULT 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th Jun 2018 4:50pm |
Perhaps I would have mentioned that until the ABS ECU received a signal from all 4 sensors it remains in diagnostic mode. 2002 90 Td5 Station Wagon
15th Jun 2018 4:51pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Great news George
15th Jun 2018 4:58pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Excellent Ray
15th Jun 2018 5:04pm |
Couple of celebratory pictures
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th Jun 2018 5:39pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5216 |
What did procta say great news mind! Plus it was an easy fix too! I knew it would have been something daft, if you have tested the system with another ECU Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
15th Jun 2018 6:04pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Nice one Grafty,
That looks cracking 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
15th Jun 2018 6:24pm |
15th Jun 2018 6:45pm |
So what’s the plan with it?
Is it a keeper, or use it for a while sell it and find another project? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
15th Jun 2018 7:01pm |
Definitely a keeper. Lots of family memories in it. Mum and Dad have said I can have it as they don't use it but don't want to see it go!
I was 6 or so when mum and dad bought it and probably about 16 when they stopped using it so most of our family caravanning holiday memories involve the RR in some way or another. I have permission to do some light modifications such as exhaust etc. But it will be staying relatively standard for the time being 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th Jun 2018 10:30pm |
