Home > Puma (Tdci) > Loss of power - split in hose.
dwilliams851
Chile 2010 Defender 110 Puma 2.4 SW Galway Green
Hello all,
I hope you can help. (I have fixed older, more simple cars before, but I'm no expert. The Defender Puma is the most complex thing I've owned, so please excuse any vague descriptions or lack of knowledge).
I was driving my wife to the airport last night and suddenly the car lost a lot of power. It would go about 80kmh (50mph) max, but any kind of slight incline meant I had to change down gears. 6th gear was useless. It feels like the turbo isn't working.
I could drop my wife at the airport and drive home slowly and the car would happily climb the steep slope up to my house in low range (which it normally needs).
I've read a bunch of topics here about turbos failing, actuator problems, whistling noises etc. I haven't noticed a whistling noise. When the car is on idle, what I think is the actuator arm is moving slightly, so I think it's working.
Unfortunately I am now on my own here (Chile), so i don't have someone to push the throttle while I look inside.
But.. maybe I should have mentioned this first.... I have noticed a split in a hose on the opposite side of the engine to the turbo, going from the manifold, forward towards the radiator. Obviously I need to replace this, but could this be the loss of power problem and what is the hose called please?
Thank you for your help.
David
Past LR's
Series 2a, Range Rover Vogue, Disco 3, Disco 2, Disco 1
Defender 110 Puma
http://www.flickr.com/photos/bambi851/
Post #712328 14th Jun 2018 1:57pm
jst
thats a split in the air intake manifold hose that comes from the intercooler.
you will be loosing any boost pressure from the turbo with this split.
i guess you have black smoke under hard acceleration as well.
change it and power will be restored. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712330 14th Jun 2018 2:15pm
dwilliams851
Excellent. Thank you very much.
Is it safe to tape it up and use the car while I wait for delivery of a replacement? Just down to the shops and back, no large journeys.
Thanks again. ---------------------------------------------
Past LR's
Defender 110 Puma
Post #712331 14th Jun 2018 2:18pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I have had the same problem in the past.
Loss of power was due to a split hose.
Here is a link to the part (intercooler hose) which may help with part numbers, description and so on.
https://www.ebay.co.uk/p/Bearmach-Land-Rov...amp;crdt=0
I replaced mine with these -
https://secure.bellautoservices.co.uk/stor...-silicone/
Hope that helps.
Be lucky Thumbs Up
Post #712332 14th Jun 2018 2:19pm
shropshiredefender
I guess that self amalgamating tape reinforced with cable ties would make a "bush repair".
Post #712333 14th Jun 2018 2:27pm
jst
yes certainly, i would tape it up with self amalgamating, gaffa or insulation tape (in that order of preference) a piece of sturdy rubber (old hose?) cable tied or jubilee clipped on top of that otherwise pressure will just blow it off. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712334 14th Jun 2018 2:32pm
dwilliams851
Excellent. Thanks for the links and the advice, really appreciated.
David. ---------------------------------------------
Past LR's
Defender 110 Puma
Post #712335 14th Jun 2018 2:37pm
Eduardo
Hi Dwilliams851
Its a common problem and in general start with a whith a whistle in the area of the turbo when accelerating.
I used mine for some weeks with several layers of duct tape (easy to found in any DIY in Santiago
Cheers and good to hear from you again Eduardo
Post #712342 14th Jun 2018 4:10pm
zsd-puma
Yep without doubt that's your problem.
Another option is a bit of old bicycle tyre over the hole with several cable ties (zip ties) or wire around it. If you get a puncture repair kit with some vulcanising solution in it you might even be able to glue the tyre to it for a better seal as well as the cable ties.
Post #712357 14th Jun 2018 6:22pm
