![]() | Home > Puma (Tdci) > 2.2 TDCi Oil Cooler Life? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7889 ![]() ![]() ![]() |
Our 2012 2.2 TDCI 110SW is currently at our local independent having a new output shaft fitted. Whilst talking to him he mentioned he'd just had a Puma with a failed oil cooler which had filled the cooling system with sticky oil which was virtually impossible to clean and ended up having to replace quite a few parts.
I just wondered if anyone has had this issue and what would be the expected life of the oil cooler? Would it be worth replacing? I was driving whilst having this conversation so wasn't paying full attention. As a mechanical numpty I've heard of the fuel cooler, but not the oil cooler? I know our's had the Q421 oil pump update recall done in 2015, is this related? Any info you have would be gratefully received. TIA ![]() Photo unrelated but some nice classics! ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3151 ![]() ![]() ![]() |
How long does it take to replace the output shaft?
I think mine needs doing and I'm trying to get an idea of cost. |
I've left it to the experts, so will let you know when I get the bill!
I did find this though https://www.ashcroft-transmissions.co.uk/f...?769007971 suggesting 3 hours for the Ashcroft replacement so suspect the OEM would be similar? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Cheers. 3 hours doesn't seem too bad. Are you going for the Ashcroft part?
Rightly or wrongly I'm not using the Ashcroft version. I've read a few mixed comments on them. I hope I don't regret this decision! James
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3632 ![]() ![]() ![]() |
there are products that you add to the coolant following a cooler failure that breaks down the oil to aid the flushing process DEFENDER 90 TDCI XS,
Interesting to know, thank you. I am rather hoping to prevent it happening in the first place.
Any comments on when or if to replace gaskets or whole oil cooler as part of a routine maintenance? TIA ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 436 ![]() ![]() ![]() |
Hmm. ![]() They mounted an Ashcroft version on mine just a few days ago. JLR themselves - not a local indie. Only time will tell if it's going to be durable ![]() |
I'll be interested to see how you get on with the Ashcroft. Very surprised JLR are using them, almost admitting bad design! Wish id known that earlier, mine was fitted today
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
In order to have them fit the Ashcroft kit
