Home > Puma (Tdci) > 2.2 TDCi Oil Cooler Life?
JOW240725
Our 2012 2.2 TDCI 110SW is currently at our local independent having a new output shaft fitted. Whilst talking to him he mentioned he'd just had a Puma with a failed oil cooler which had filled the cooling system with sticky oil which was virtually impossible to clean and ended up having to replace quite a few parts.
I just wondered if anyone has had this issue and what would be the expected life of the oil cooler? Would it be worth replacing?
I was driving whilst having this conversation so wasn't paying full attention. As a mechanical numpty I've heard of the fuel cooler, but not the oil cooler? I know our's had the Q421 oil pump update recall done in 2015, is this related?
Any info you have would be gratefully received. TIA Thumbs Up
Photo unrelated but some nice classics!
 James
Instagram @suffolk_rovers
Post #711268 7th Jun 2018 4:34pm
Zed
How long does it take to replace the output shaft?
I think mine needs doing and I'm trying to get an idea of cost.
Post #711270 7th Jun 2018 4:40pm
JOW240725
I've left it to the experts, so will let you know when I get the bill!
I did find this though https://www.ashcroft-transmissions.co.uk/f...?769007971 suggesting 3 hours for the Ashcroft replacement so suspect the OEM would be similar? James
Post #711275 7th Jun 2018 4:58pm
Zed
Cheers. 3 hours doesn't seem too bad. Are you going for the Ashcroft part?
Post #711284 7th Jun 2018 5:47pm
JOW240725
Rightly or wrongly I'm not using the Ashcroft version. I've read a few mixed comments on them. I hope I don't regret this decision! James
Post #711317 7th Jun 2018 8:04pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
The gasket on my oil cooler went on my 2.2 tdci at about two years and filled coolant with oil. Dealer dealt with it under warranty including replacing the coolant pipes and flushing it a few times. So I guess it is a known fault. Not sure if there is anything preventive that can be done.
Post #711344 7th Jun 2018 8:46pm
LR90XS2011
there are products that you add to the coolant following a cooler failure that breaks down the oil to aid the flushing process DEFENDER 90 TDCI XS,
Post #711373 8th Jun 2018 5:23am
JOW240725
Interesting to know, thank you. I am rather hoping to prevent it happening in the first place.
Any comments on when or if to replace gaskets or whole oil cooler as part of a routine maintenance? TIA Thumbs Up James
Post #711382 8th Jun 2018 6:51am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Hmm. Neutral The spline needs lubrication. I don't know how new grease may enter the spline if not accessible.
They mounted an Ashcroft version on mine just a few days ago. JLR themselves - not a local indie.
Only time will tell if it's going to be durable Sheep
Post #711496 8th Jun 2018 8:13pm
JOW240725
I'll be interested to see how you get on with the Ashcroft. Very surprised JLR are using them, almost admitting bad design! Wish id known that earlier, mine was fitted today Sad Lets see who's lasts the longest Big Cry James
Post #711501 8th Jun 2018 8:29pm
Julie
In order to have them fit the Ashcroft kit Embarassed I had to be very very persuasive ...
Post #711505 8th Jun 2018 8:38pm
