![]() | Home > Puma (Tdci) > cooling puma 2.2 |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
I have change the oil cooler, oil in the cooling instalation. My difficulties is that when I filling the engine, the temperature is very low (6 °C) during 10 or 15 minutes and then go up quickly to 110° C .... Is there a good way to fill up the cooling circuit ? Thanks for Help Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Hi,
I have change the thermostat, seems to be ok. Nevertheless it is an afull job and stil oil in the cooling circuit even if I have work a lot to try to clean it. Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
b_jabu Member Since: 30 Nov 2017 Location: KZN Posts: 1 ![]() ![]() ![]() |
it sounds to me like you have a hairline crack in the cylinder head. i have looked into this alot and its strangely uncommon outside South africa. here however its seems to be every other one. locally there have been guys with new (less than 50,000kms) who have traveled 20,000 kms with a cracked head. the only indication there was a problem was when the water level kept dropping. when everything else had been ruled out, it lead to the head being cracked (or at least the gasket blown). this seems to be a problem that gradually gets worse and the typical diagnostics don't raise alarm bells. in many cases JLR have replaced the whole engine for nothing, i even heard of one chap getting a new engine after he chipped it and was just out of warranty. the typical pressure tests don't get up to the temperatures where the crack opens and so the test come back negative. you will find that towing uphill on a hot day you have problems.
what has been suggested here is the cooling system just isn't good enough for the pretty tried and tested engine. personally i have installed a larger intercooler and i would suggest this is a mod that everyone should do to help the system run cooler and prevent these cracks. |
CaptainDan Member Since: 14 Apr 2017 Location: Victoria Posts: 53 ![]() ![]() ![]() |
Hi Yes the head is the problem and as you describe it has been a very gradual lost of coolant hardly notice it. In my case it was a failed EGR let water into the engine and caused the problem vaporising through the exhaust. It turns out the head was cracked and warped requiring an new head Mega $$$$$ repair just before Christmas
Hi All, unfortunately another tale of woe and failed 2.2 Duratec engine, since my last post which ended up costing 8.5k AUD and having the ERG fixed and a new head etc etc today I find that the cooling system is being presurised from the engine some how, either another cracked head, blown head gasket or cracked cylinder its done 19k since this repair.
The cooling system is under pressure which has destroyed my Allisport radiator and who knows what else A radiator specialist today confirmed the failed radiator was not as a result of stray current or cooling water contamination. The engine has only done 138K from new and I am at a point where I seriously consider my options of keeping this vehicle. A question what experience or advice can anyone give me on replacing the 2.2 engine with something more reliable like an Izusu motor. Thanks |
