Home > Technical > 2013 Defender 90 Central Locking / Actuator Issues
DXB90
2013 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Afternoon All,
After a read through of all posts still cannot find an answer to the problem I am having.
One morning the central locking decided to make a very strange noise initially on the drivers door like a whirring and it would not unlock, like the the door lock on the inside was stuck. I managed to get in through the passenger side and pull up the door lock from the inside, all was then well for a few days.
The whirring then started again usually there would be a small delay and then the noise would happen both on locking and unlocking. It was close to a service (still going to the main dealer here in Dubai even though outside of warranty) so I thought I would leave it for a couple of weeks and they would look at it then. The morning of going to the dealership, disaster, would not unlock, whirring alarm going off and very difficult to even get into the car, though it started fine once this had happened. From a quick search I presumed it would be one of the actuators that needed replacing so as it was going for a service thought sure no major issues.
How wrong could I be... 4 weeks later and numerous follow ups from the main dealer through advise from TSB (presumably locally and not the UK) I have been presented with a solution which is and wait for it...
Replace the whole system to a newer model.
Ie...
Switch alarm
Actuator oddly only 2 pieces
Module - Door lock and alarm
Kit - Wiring
Coil - Starter motor field
Remote control system - transmitter
Receiver - Radio remote control
Total price converted in Sterling - 1509.50 including labour with a 30% discount on the RRP of the parts.
There other suggestion is too disable the central locking and use the key manually and all will be fine, obviously this is not ideal at all.
Would appreciate any advice from anyone familiar as this seems like using a hammer to fix a leak!!!
Tim
Post #710576 3rd Jun 2018 11:02am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Just disconnect the actuators and remove the rods to the lock 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #710580 3rd Jun 2018 11:39am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
That’s sound like silly money.
Asuming you are the diy type.
First check the wires in the flexible tube between door and pillar. LR used very stiff wires and perhaps you have a problem
There.
Then to do Some more investigating you can switch parts from the left side to the right side. Starting with the actuator. To see which is the culprit. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #710581 3rd Jun 2018 11:52am
mk1collector
As above, sounds like one of the actuators has gone dry so is making the noise. Listen to which door the noise comes from and replace that actuator then check the wires in rubber boot of which door doesn’t open as some of the wires will probably be broken. Ray
My build thread
Post #710612 3rd Jun 2018 5:08pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Sounds like they're taking the proverbial.
Mine did something similar. Initially, one slow actuator (one door always the last to unlock) - i.e. it was still working, but making a whirring noise for ages on a rear door. Then suddenly no door opening at all and a blown fuse (can't remember which one - sorry - but it was a 15A) which disabled all the locks and I needed to open the drivers door with the key to get in.
The issue was a broken wire in the gaiter between the pillar and the door as Tdi4 says above (causing a short).
Hope it's this as it's an easy fix. Wires - just use anything more flexible and robust than the cr@p JLR use. The actuators are relatively cheap too if it's that that's broken.
Certainly wouldn't be paying £1500!!
Good luck.
Post #710613 3rd Jun 2018 5:12pm
NickMc
Try Mark at http://salukimotorsport.com if you want a second opinion. Nice guys and expats.
Post #710672 3rd Jun 2018 10:27pm
DXB90
Thanks all, have made a call to Land Rover UK and expecting a call from Global.
Have spoken to the dealer here and they are claiming that all wires in the rubber boot have been checked and no breakages.
Will update once I hear all. Have used Mark before so will reach out too.
Tim
Post #710709 4th Jun 2018 11:22am
Hal
I guess the other doors work ok?
If it's not the wires and the other doors work then the next check is the actuator motor.
Google for Actuator - Drivers Door - FUD500020 - Genuine. Less than £40.00 30 minute job to change it if you're being careful with the door card clips.
So even at dealer costs if you don't want to do it yourself you're looking at perhaps less than £150, a tenth of their first proposal to you.
Post #710728 4th Jun 2018 2:03pm
DXB90
Yes the other doors were working all ok.
Honestly no idea now. Land Rover Global (Dubai) came back and have basically agreed with the dealer remove and replace all.
Now in the process to get something more sensible out of them.
Post #711051 6th Jun 2018 8:58am
Doc P
Tim
Mine had broken just at the door end of the gaiter - so the broken end was sitting behind the door card. Wouldn’t be obvious unless you really looked.
I’d double check.
Post #711108 6th Jun 2018 4:06pm
