![]() | Home > Maintenance & Modifications > Puma dash CANbus controller |
Rigg321 Member Since: 29 May 2018 Location: Florida Posts: 1 ![]() ![]() ![]() |
Are these still available?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Not available yet - mid/late June still the target. Will update when I have more info
![]() Click image to enlarge Getting there! ![]() ![]() |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Where would the loom plug into Martin
Awful photo sorry. So much for iPhones having the best cameras...
Try this ![]() Click image to enlarge Nope still awful. Must bring a proper camera with me tomorrow ![]() ![]() ![]() |
Am I right in thinking that’s where td5 binnacle plug fits
No there is a wiring loom which plugs into the Td5 connectors (3 of them), one into this box and one into the Puma gauges
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
Very interested in this, would go well with my puma/tdi dash conversion. Looking forward to the release
All gauges and warning lights work - see the videos I posted earlier in the thread: http://www.defender2.net/forum/post707908.html#707908 Yes it is connected to the Td5 ECU as it has to get various signals from it, it gets these from the dash connectors. The Tdi version is similar but interfaces directly with the coolant sensor and alternator W terminal. A kit will comprise of the controller as above, plus the correct loom for your engine. These looms are plug-and-play as far as possible, with either no or very little hardwiring required. A basic loom will also be available if you have modified electrics and don't need/want a plug-and-play loom. The controller has been designed to support other engines, but Tdi and Td5 will be available from the start. ![]() ![]() |
iceshj Member Since: 16 Jan 2016 Location: Southampton Posts: 28 ![]() ![]() |
Hi Martin,
Any more news on these including costs? Thanks Dave Defender 90 softop (in bits) Range Rover Hybrid SVAutobiography Discovery 3 HSE Kawasaki ZX12R |
Lstheida Member Since: 29 Oct 2017 Location: Drachten Posts: 8 ![]() ![]() ![]() |
Super this lookes realy promising. the Puma dash is build in my td5 and up and running. just need to get the dash up and running.
(no need for a loom, would have made a lot of things easyer). keep my posted with the progress. Lennard. |
I’m about to install the Puma dash this week, so really eager to hear about this module Defender 90 softop (in bits)
