JDG
![](templates/vbnew/images/spacer.gif)
Green Machine wrote:Well, I have found clutch pedal mod nirvana! And it came courtesy of our Australian cousins - a vital piece of information that is missing from our pages on this subject. PUT THE SPRING INTO THE PEDAL BUSH FIRST!! Then, once it is in, fully depress the clutch pedal and chock it with a piece of wood across the footwell (or get an assistant to hold the clutch down). You can then use a pair of needle nosed pliers to position the two loose ends of the spring into their respective bushes. Piece of cake - took 2 minutes. I should have done a little bit more googling before making a start and spending all afternoon messing around with it.
I hope this will be helpful for those Td5 owners who are yet to undertake this modification, follow this method and it really is an awful lot easier! ![Thumbs Up Thumbs Up](images/smiles/icon_thumbs.gif)
Quote:
Just used the wood chock and fitted easily.
Many thanks for your post.
Took the spring off first, but still very hard pedal as if there is another spring, but I cant find one.
18th May 2018 5:03pm |
