Home > For Sale & Wanted > [Wanted] Defender 300tdi 110 SW County in ALPINE WHITE
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hi,
Looking for unmolested original RHD Defender 300tdi 110 SW County in original ALPINE WHITE with County stickers etc.
Please PM if willing to sell with expected price. Private Buyer.
Thank you.
APK
Post #706793 12th May 2018 6:52pm
sako243
I was going to say I have one but I wouldn't sell it. Then I realised it's now a USW with a seat of seats from an L322, pegged Ashlocker front and rear, winch and raised intake. So doesn't fit your bill, but it is Alpine White with (faded) stickers... Laughing
Good luck Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #706801 12th May 2018 7:14pm
APK
Quote:
Good luck
Thumbs Up
Post #706936 13th May 2018 5:46pm
APK
Hi all, I came across the following vehicle and would appreciate your comments on the following please:
(1) Is it straightforward to fit an aircon on a 300tdi? Can you recommend a workshop that can do this near Guildford/West Sussex please?
noticed that the rivets along the side and back are of a different size to the factory fitted ones on my other Defender 110
(2) What would be the most likely reason for someone to change the rivets along the side and rear of the vehicle on both sides? Could it be that a previous owner may have drilled them out and replaced to pre-empt rust? or perhaps a more serious damage? How would I check for more serious damage?
(3) Is it relatively easy to get these oversized rivets removed, and have them replaced with the original sized rivets?
(4) May I know where to get the build specs of this vehicle if I have the Registration# and Chassis#? i.e. I want to get details such as the original paint code, original engine# of the vehicle etc. Topix did not give me this info
(5) As attached, when I enter the chassis number under Topix there are 'Outstanding Campaigns' and 'Activity Stream' - May I know if these are alerts for the model or for this specific vehicle please?
Many thanks, APK
Post #708295 20th May 2018 11:45pm
NickMc
Probably had some paint work and/or replaced the Cappings on the tub. Yes you could remove them and replace with the proper closed head rivets if you wanted, as long as the holes aren’t massive underneath the big rivets.
Land Rover air-con of this era? Surely just open the vent flaps? Laughing yes you could retrofit it, the standard factory aircon takes up the space at you knees and isn’t great.
Post #708370 21st May 2018 2:32pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
The rivets tend to look big and fat when they’ve been sanded down and painted over. It’s easy enough to replace them that you have to wonder why someone would just sand them.
Post #708414 21st May 2018 5:32pm
APK
NickMc, JimC, thank you for your comments. Went through the online MOT history, a 2013 entry mentions:
"Reason(s) for failure
Nearside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Rear Vehicle structure excessively corroded within 30cm of towbar mounting (6.6.6)"
Different sized rivets were probably a result of fixing above.
Thanks again Thumbs Up
Post #708499 21st May 2018 10:32pm
NickMc
That sounds like the rear crossmember possibly. Check there’s a row of spot welds and it’s not had the sides and rear light panels glued on. People even fake the spot welds- seen it in filler and with a round head punch to fake them. Check along the edge were the wheel housing meets the outer tub sides? it’s rare to find something that age now that hasn’t had some “love” over the years.
Post #708514 21st May 2018 11:56pm
NickMc
Oh and the bit you’ve circled in the last post is for holding the bottom door seal in/ carpet down part no AFP710120 Replace the seal at the same time. Aftermarket versions don’t last as long in my opinion, my guess is cheaper steel, cheaper galvanising, someone does a stainless steel version I think maybe YRM?
Post #708515 22nd May 2018 12:00am
APK
Thanks NickMc.
I believe she was sold. Keeping a lookout for another Very Happy
Post #708688 22nd May 2018 9:32pm
APK
Still looking for an original unmolested 300tdi in Alpine White with 'LAND ROVER 110 DEFENDER COUNTY SW TDI' on the V5.
Similar to the pic below (taken off FB). Appreciate any leads. Thanks!
 APK
MY2016 110 Adventure Corris Grey
MY1997 110 County Station Wagon 300 Tdi Alpine White
Post #739060 6th Nov 2018 7:03pm
APK
Took me more than 3 years since this post... finally found! Very Happy
 APK
Post #917494 17th Aug 2021 11:25pm
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Well worth the wait, that looks lovely Thumbs Up cheers Paul
Post #917498 18th Aug 2021 5:03am
Very nice. I do like a white 110. Just needs white wheels to match (IMHO, of course Laughing ). Darren
Post #917508 18th Aug 2021 7:12am
APK
Thanks Paul and LandRoverAnorak
I was thinking of 16" X 8" Tuff Torque modular steel 'Silver' on BF Goodrich APK
Post #917529 18th Aug 2021 11:13am
