Home > Puma (Tdci) > Heavy Duty Springs |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I would suggest the first port of call is to check what springs you have. If you clean them up you should see dabs of paint in colours reflecting the part #. This may help:
Road spring data Road spring Part number Colour code 90 2 seat utility (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side NRC 9448 Blue/red Rear - Passenger side NRC 9449 Yellow/white 90 2 seat utility (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB101230 Green/yellow/red I would then check the spec of the spring, and make a decision about what you want to upgrade to... This may also help: http://bilashakaflowers.com/LandroverSprings.htm There are some OEM springs for HD application available from LandRover if you don't already have them...NRC9462 and NRC9463... I have bespoke springs from a company in Sheffield. See http://www.defender2.net/forum/topic49065.html Craddock does Old Man Emu upgrade springs for a 90... I would definitely install spring isolators to improve the ride and reduce road noise Just some of my findings when I upgraded my own suspension (altho I was softer not harder!)... Hope that's useful Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 11th May 2018 3:03pm. Edited 1 time in total |
11th May 2018 2:48pm |
Pic showing the colour paint dabs to confirm what you have installed today...
Click image to enlarge Left one is green/green/white (rear of a 110 CSW) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
11th May 2018 2:58pm |
BykerPete Member Since: 02 Feb 2015 Location: Midlands Posts: 159 |
Thanks Martin.
Are there any specific spring isolators that you’d recommend? Pete. |
11th May 2018 3:41pm |
http://www.defender2.net/forum/topic52898....+isolators
http://www.defender2.net/forum/topic23909....+isolators Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
11th May 2018 4:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20222 |
+1 For the isolators from me too. They get my vote. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
11th May 2018 5:31pm |
Thanks gentlemen. And does anyone have an opinion about HD Springs on rear only - or should they be fitted all round? (Assuming that the current springs are not HD)
Pete. |
11th May 2018 5:35pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6085 |
You can fit HDs in just the rear, in fact if you fit HD's up front without much extra weight there then handling (and looks) can be a bit *strange*
11th May 2018 9:46pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
As people on here know my 90 is very heavy, re plated and both my 57 plate and now 12 plate have Extream HD springs +1in on the back only with the biggest roll bar they do. Always been a good set up for me vehicle looks level at all times even with a trailer. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
11th May 2018 10:08pm |
Thanks Everyone
Looks like I’ve got these on the rear of my 90 Click image to enlarge But the Green/Yellow/Red is on the passenger side rear. However, Still sagging a bit at the rear should I perhaps go for a HD or Extreme HD with a 1 inch lift? And if I do, do I need to do anything to the front, or change any other parts that I’ve seen mentioned before? Thanks, Pete. |
13th May 2018 2:45pm |
Pete
IMHO you are heading in the right direction, but only you will know for sure once you ave done the mod and seen if you are getting the result YOU want, I would do rears first, and then to fronts later if you decide you need to do it... Changing all 4 at once is a long day Remember you may need to re-align your headlights Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
13th May 2018 3:28pm |
Thanks Martin. Very helpful.
If I raise the rears by 1” do I need to alter the propshaft or radius arms etc. Also, will I need to do any of this if I also raise the fronts by 1 inch? Pete |
13th May 2018 5:25pm |
I dropped the rear by 4-5 cm, and the propshaft was fine. Not sure about raising, however with the weight you have, I would imagine that your vehicle is just sitting as it left the factory (the extra weight will push it back to standard-ish?) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
13th May 2018 8:58pm |
prop should be ok, when you look at the amount of axle articulation there is as standard.
13th May 2018 9:23pm |
Click image to enlarge Okay. Some very useful advice thee. Thank you. So, before I pull the trigger, would you say that this is a bit low to you? Pete. |
15th May 2018 8:42am |
