Home > Technical > Fuel pipe connectors for TD5
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Well, today I removed the fuel tank and managed to break one of the connectors on the fuel pipe as I was trying to remove from the fuel tank. Does anyone know if these are available to buy?
Post #706789 12th May 2018 6:23pm
rallysteve
I feel your pain, I had a similar issue when refitting my tank a few years ago.
Only option other than replacing the whole pair of plastic hoses is to use some of these. I fitted them with a hot air gun to soften the pipe.
http://www.4x4overlander.com/product/nakat...nes-set-2/
Don't loose the black clip though!
Post #706792 12th May 2018 6:36pm
dorsetsmith
Don't loose the black clip or its new pump
7.89mm ID6 Fuel line quick connector male connector
https://www.aliexpress.com/item/7-89mm-ID6...81272.html
Post #706805 12th May 2018 7:31pm
NickMc
If you’re really stuck and can’t get anything closer, I might part with one from my collection of second hand clips...if I can find them Laughing can’t promise the same colour though.
Post #706833 12th May 2018 9:50pm
StevePotts
United Kingdom 2001 Defender 110 Td5 CSW Oslo Blue
[quothtte="rallysteve"]I feel your pain, I had a similar issue when refitting my tank a few years ago.
p://www.4x4overlander.com/product/nakatane...nes-set-2/
Steve[/quote]
I had the same problem. I used these too (www.4x4overlander.com/product/nakatanenga-connector-for-fuel-lines-set-2). I joined the new nakatenga parts to lengths of new pipe and then standard in-line fuel pipe connectors to join the new pipe lengths to the old. I couldn't get enough heat from a hairdryer. I ended up heating some cooking oil on the cooker and warmed the pipe ends in that before fitting. After some experimenting I found that about 20 seconds in oil at about 130 degrees worked well (used my wife's jam-making thermometer to assess the temperature). Carrying hot oil in thermos flask enabled me to join pipes outside without removing them completely. The extra length of new piping gives some useful slack for easy disconnect when removing the tank/pump in future. Thumbs Up
Post #706844 12th May 2018 11:57pm
StevePotts
Steve[/quote]
Post #706845 12th May 2018 11:58pm
dorsetsmith
Fuel pipe connectors for TD5 fuel pump
4.94mm hole
Post #706873 13th May 2018 8:52am
JustFX
Thanks for the responses. I will revisit the pipes today when I get a chance to get back up there. It is at my Uncle's as he is better at Welding than me. I thought the clip was part of the connector but by the looks of the picture, Dorsetsmith posted it isn't.
Annoying that there aren't many online UK sellers of these connectors. Scary price for some ally connectors from Nakatanenga, but then again most of the Nakatanenga range scares me on price.
Post #706876 13th May 2018 9:24am
NickMc
Try your local Wurth dealer.
Post #707018 13th May 2018 11:25pm
