Home > Td5 > 1999 TD5 Defender will not start. |
have you check your fuel presser at the engine your looking for 4 bar
11th May 2018 7:20pm |
PrettyGood Member Since: 11 May 2018 Location: Kusel Posts: 19 |
Unfortunately no... I have a fuel pressure tester but not one that I can connect to to this setup.
11th May 2018 7:28pm |
There is a fitting coming out of the fuel regulator going to the cooler. I may be able to connect my tester there. Should it be 4 bars coming out of the regulator?
11th May 2018 7:36pm |
yes
11th May 2018 7:37pm |
Click image to enlarge |
11th May 2018 7:48pm |
Great! I will give that I try.
Thanks! How can you test the voltage coming from the CKP? Do you not need an oscilloscope to see the pulses? Or is it a constant DC level? |
11th May 2018 7:53pm |
12th May 2018 10:42am |
oscilloscope can be used or multimeter ac voltage CKP is an wire coil around magnet
12th May 2018 10:54am |
So I just tested that with a volt meter and it is putting out .583 volts AC with slight variation.
12th May 2018 11:37am |
I just had the strangest thing happen. The was testing the output of the CKP while cranking and the engine came to life. I revved it up and it ran for a few seconds then stalled. I started it right up again and it ran for about a min then stalled. Now I can not get it to start again.
12th May 2018 11:44am |
1. have good check wiring for the CKP
2. is showing dash then engine stops |
12th May 2018 12:43pm |
Checked from the CKP connector to the ECU connector and both wires tested good. Cleaned both connectors again and plugged it back in but still not starting. I wish i knew what made it start earlier today but I cant seem to replicate. I was testing the CKP while cranking the engine, but I was also changing the settings on the muli meter when it fired up.
12th May 2018 1:19pm |
The amber engine light comes on for about 3 seconds when you turn the key on. It also flashes when running the fuel air purge cycle.
12th May 2018 1:24pm |
That's OK |
12th May 2018 1:27pm |
