Home > Td5 > 1999 TD5 Defender will not start. |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
If you can borrow one, try replacing the battery. You may be getting enough voltage drop to stop the fuel pump relay from closing.
Try putting your finger on the fuel pump relay whilst cranking. If it vibrates that's your problem. Happened to me; took ages to resolve. |
12th May 2018 5:28pm |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
If you found oil on the Ecu connector i would say you have a faulty injector loom.
Check for oil on connector under from rocker cover, if you find oil, there maybe your issue. |
13th May 2018 1:47pm |
PrettyGood Member Since: 11 May 2018 Location: Kusel Posts: 19 |
I will definitely try bump starting it. I changed out the CKP (CPS) but it did not fix the problem. I managed to get it to start for about 20 seconds while wiggling the red connector on the ECU, but could not repeat. I also tested the fuel pressure at the regulator and it had 4 bar. I have another battery I can try but the current one is pretty new. I changed out the injector loom when I found oil in the ECU connector. I also changed the injector seals and washers.
19th May 2018 7:05pm |
No luck with the bump start. It didn't even try.....
22nd May 2018 4:17pm |
Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35 |
Make sure the connector on the injector harness where it exits underneath the rocker cover is fully pushed into place.
22nd May 2018 7:39pm |
Yes for sure... cleaned it several times and tested it out to the ECU connector and it tested good.
22nd May 2018 7:50pm |
Its sounding more & more like oil contamination inside the ECU.
Pull off the red ECU plug and look inside for signs of oil then leave it in position over a paper tissue and check later for oil droppings. |
23rd May 2018 7:35am |
I would still suspect the CKP. I know you changed it but I can't think about anything else on the moment.
I thought I did a job close to you in January but according to Google earth it was still 88 km. Click image to enlarge Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Yes, the red connector on the ECU was full of oil but I took the ECU out and cleaned it. I also cleaned the connector and replaced the injector loom, seals and copper washers. I am pretty sure that's what started the problems but no way to confirm.
23rd May 2018 7:49am |
I suspect the same thing about the CKP. I ordered the cheap LR terrafirma code reader yesterday to see what it can tell me. It will be a few days before it arrives.
23rd May 2018 7:53am |
Puttlingen is a nice area. I live in the Glan Valley which is nice as well.
Click image to enlarge |
23rd May 2018 4:12pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Did you actually change the crank sensor or just clean it ?
If you replaced it, what make did you replace it with ? A certain blue box brand are notorious for not letting the engine start. Did the sensor have the shim NSJ 000010 fitted, if not it might be worth fitting one to see if it helps. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
23rd May 2018 5:27pm |
I did replace it and it was with a cheap one... so i am a bit suspicious about it. I was wondering about the Shim. I don't think it had one. At least I didn't see it if it did. It also didn't have a O ring on it. Is that normal for an early TD5?
23rd May 2018 6:52pm |
The shim was fitted under a service bulletin as some had it missing.
Mine had been running for many years without it with no issues and then it started missing and the non existent shim was the problem. It is possible that the shim is still in place on the casing but if not for a couple of euros it is worth a try. My sensor does have the O ring but looking on the web they are shown with and without. Did the old sensor have an O ring, if it did move it over to the new sensor. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
23rd May 2018 7:04pm |
