Home > Td5 > 1999 TD5 Defender will not start.
Page 3 of 3 <123
PrettyGood
Germany 1999 Defender 110 Td5 SW Alpine White
The old sensor did not have the O ring but the new one does. I tried it with and without and it didn't make a difference. I think the shim could be significant, but also the sensor itself. Could have been bad out of the box. When I put a multi meter on it and test for AC volts, I only get about .6 volts while cranking the engine. The book says its should be 2 or 3 volts. Who makes a good brand of CKP that will not cost 150 pounds?
Joseph
Post #708822 23rd May 2018 7:15pm
bob neville
I have a Lucas one in mine but the prices seem to vary wildly.
https://www.island-4x4.co.uk/crankshaft-cr...28315.html
2013 Defender 90 CSW - sold
Post #708824 23rd May 2018 7:37pm
PrettyGood
Thanks Bob!
Post #708829 23rd May 2018 7:48pm
NickMc
I’ll agree with that had a few cheap sensors and MAF junk brand new out of the box. You’d be better with a mid max on your DVOM, you won’t really see much without an oscilloscope though it’s too quick a rate to pick up a flaw really. The shim is a funny old thing brought out to cure intermittent faults still see ones that have never had it and run fine. More FPR leaks the ruin the wiring to the sensor (which is shielded cable). Try maybe an Intermotor branded one.
Post #708845 23rd May 2018 9:21pm
PrettyGood
I have an old fluke 77 and I don't think it is capable of min/max. I wouldn't mind picking up an O scope though. Haven't used one in 25 years but used to use them everyday when I was an electronics tech. I will look at the intermotor brand.
Post #708851 23rd May 2018 9:57pm
Page 3 of 3 <123
