Home > Puma (Tdci) > tickover |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Any one know how to increase the tick over on the Puma. No doubt it needs plugging into something ?? but is it a Land Rover / Ford only testbook thing or can the aftermarket products do it.
The dpf rattle on tick over I have had for months now is driving me up the wall just a small increase of revs sorts it. If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
9th May 2018 7:29pm |
probably easier to fix the rattle.
Increasing the idle will also mean the clutch gets a harder life when it's disengaged/reengaged. |
10th May 2018 1:27pm |
I'm not up for replacing the dpf, engine mount off, breaking rusty turbo studs ect no thanks. Then there is the cost of a new one owch If everything is under control you are not going fast enough.
10th May 2018 3:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20345 |
There is the cold start thing that sits the revs up about 100RPM, but as far as I am aware is automatically initiated on and turned off by the ECU If and when required.
Best people to advise is tuners, Gary @ Alive or Pete @ BAS. Most of these things are possible, but the long term effect needs to be thought about. Off topic and not applicable to you issue but an example; I'm glad my clutch switch is bypassed, except a totally different thing. Gets rid of that arrigivating increased rpm hunting idle in low range. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th May 2018 4:58pm |
