Home > Puma (Tdci) > tickover
noworries4x4
tickover
Any one know how to increase the tick over on the Puma. No doubt it needs plugging into something ?? but is it a Land Rover / Ford only testbook thing or can the aftermarket products do it.
The dpf rattle on tick over I have had for months now is driving me up the wall just a small increase of revs sorts it. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #706258 9th May 2018 7:29pm
I don't think there is any easy way to do this, unfortunately, other than possibly blowing four grand or so on a hand throttle.
Post #706314 9th May 2018 9:21pm
zsd-puma
probably easier to fix the rattle.
Increasing the idle will also mean the clutch gets a harder life when it's disengaged/reengaged.
Post #706426 10th May 2018 1:27pm
noworries4x4
I'm not up for replacing the dpf, engine mount off, breaking rusty turbo studs ect no thanks. Then there is the cost of a new one owch If everything is under control you are not going fast enough.
No Worries 4X4
Post #706450 10th May 2018 3:55pm
There is the cold start thing that sits the revs up about 100RPM, but as far as I am aware is automatically initiated on and turned off by the ECU If and when required.
Best people to advise is tuners, Gary @ Alive or Pete @ BAS.
Most of these things are possible, but the long term effect needs to be thought about.
Off topic and not applicable to you issue but an example;
I'm glad my clutch switch is bypassed, except a totally different thing.
Gets rid of that arrigivating increased rpm hunting idle in low range. $W33T $0U7H3RN $UG4R
Post #706456 10th May 2018 4:58pm
