Home > Puma (Tdci) > Engine clatter at 2100 rpm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
sound like a clutch plate rattle
25th Apr 2018 6:58pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1609 |
I’ve also had this before and you swear it’s te clutch making te noise but the exhaust fixings has cracked on the down pipe
25th Apr 2018 7:40pm |
Yeti110 Member Since: 04 Jan 2018 Location: Skåne Posts: 27 |
Thanks for the replies. I really thought it was more of an engine related sound. I'll check the downpipe fittings. The clutch plate tightening is a way bigger problem. Is there a way to confirm it is the clutch plate, other than doing it?
25th Apr 2018 7:54pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6292 |
it's an old favourite
check out the bolts holding the exhaust manifold / heat shield to the head |
25th Apr 2018 8:47pm |
Will do. Thanks so much for your time.
25th Apr 2018 9:20pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Ahhh it's difficult because there's a few things it could be. Few other things to check are weeping injectors and rattling turbo heat shield!
25th Apr 2018 9:33pm |
Have a quick look on google for “LUK clutch failure diagnosis” if not and it has all the tests in a PDF you can do to narrow down a clutch fault. I’m not sure if you can access their repxpert site if you’re not in the motor trade though sorry.
25th Apr 2018 9:35pm |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 |
If it is piston noise, it can be the vcv valve
26th Apr 2018 10:50am |
Hi All,
I thought I just add this note in case anyone ever runs into this problem, albeit unlikely. I'm ashamed to say that the cause of this problem seems to stem from my overfilling with oil, on the last oil-change. I changed the oil again last night and the rattle has all but disappeared now. I hope I haven't caused any permanent damage. Sorry for wasting your time.... |
17th May 2018 2:01pm |
