Home > Technical > Difference between ABS and non-ABS axles
hank
Hello, quite a specific one for you today...
There is only one part number listed for front driveshaft assemblies; TDB500280 (RHS) and TDB500290 (LHS)
Some research suggests these are suitable for both ABS and non-ABS models. Having seen a shaft, the ABS reluctor ring is machined into the shaft which suggests the ABS reluctor ring must be present in non-ABS axles and is just not used/sensed on non ABS models.
So is it reasonable to assume that a non-ABS axle can be converted to an ABS axle by simply fitting an ABS upper swivel king pin (the type with the hole for the ABS sensor) and an ABS sensor?
Post #702784 24th Apr 2018 7:44am
dorsetsmith
yes
ABS reluctor ring is machined into the CV
Post #702786 24th Apr 2018 7:55am
hank
Sound, thank you Thumbs Up
Post #702789 24th Apr 2018 7:59am
roel
Without abs CV's are stronger.
 Roel
2003 90 Td5 (2009-now)
Post #702811 24th Apr 2018 10:41am
hank
Roel, that must be a pre 2007 non Puma CV?
Post #702814 24th Apr 2018 10:47am
roel
Yep td5, but are they different except for the abs? My td5 doesn't have abs so I don't need the cut outs.
My experiences:
ABS CV:
Non ABS CV:
With the none ABS only the internal break.
But now I have Aschroft front and rear. Yep it is an investment, but if they give 5 year waranty with 35" tyres that I use I am sure they will be OK. Roel
Post #702837 24th Apr 2018 12:45pm
hank
Further to this, I removed the upper king pins from a Puma axle to find non-ABS shafts...
So don't assume all Puma axles have ABS type shafts!
Post #703511 27th Apr 2018 10:10am
dorsetsmith
on 07 Puma LRJ may have been using up none abs axle from stock
Post #703523 27th Apr 2018 11:12am
hank
It is an early Puma axle so quite possible
Post #703534 27th Apr 2018 11:41am
