![]() | Home > Technical > Difference between ABS and non-ABS axles |
So is it reasonable to assume that a non-ABS axle can be converted to an ABS axle by simply fitting an ABS upper swivel king pin (the type with the hole for the ABS sensor) and an ABS sensor?
yes ![]() Click image to enlarge ABS reluctor ring is machined into the CV Last edited by dorsetsmith on 24th Apr 2018 8:01am. Edited 3 times in total |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Sound, thank you
Without abs CV's are stronger.
![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Roel, that must be a pre 2007 non Puma CV?
Yep td5, but are they different except for the abs? My td5 doesn't have abs so I don't need the cut outs.
My experiences: ABS CV: ![]() Click image to enlarge Non ABS CV: ![]() Click image to enlarge With the none ABS only the internal break. But now I have Aschroft front and rear. Yep it is an investment, but if they give 5 year waranty with 35" tyres that I use I am sure they will be OK. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Further to this, I removed the upper king pins from a Puma axle to find non-ABS shafts...
So don't assume all Puma axles have ABS type shafts! |
on 07 Puma LRJ may have been using up none abs axle from stock
It is an early Puma axle so quite possible
