![]() | Home > In Car Electronics > My Double din install has started (no radio yet...) |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
You've inadvertently convinced me to go for a flip out single din
![]() Mini Countryman Cooper S Morgan Plus 8 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3800 ![]() ![]() |
^ It's not TOO bad, just take your time doing it,
I did think about a single din but when your using them they hide the buttons and the double din imho looks more up to date? ![]() |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Unfortunately you have to extend at least 1 switch. The left top one.
In the round hole i put the Check tempIII ![]() Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I cut the circle off mine. Shaped the edge to match and then painted it. 👍
![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
nihwrd Member Since: 12 Apr 2012 Location: Somerset Posts: 28 ![]() |
I didn't have to extend of any my looms, but it is tight. Don't forget to trim the corner on the clock.
I've got nothing in the circular hole (yet). ![]() Click image to enlarge Nick |
+1 ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
Looks nicer without the circle. 👍🏻 TheThunder Rolls🇬🇧🇺🇸
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
Roy, Did you change the leds in the switches or did you find some other way of changing the colour? I’ve been wanting to change mine to red to match the rest of my dials and back lights, but as always never got got round to doing anything about it yet. |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
http://www.defender2.net/forum/topic30623-60.html Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Beeder Member Since: 19 Nov 2017 Location: Nuneaton Posts: 17 ![]() ![]() |
I had to extend three switch’s, don’t forget you have to remove the metal bracket in the dash and push the plastic heating duct back a little if your using a pioneer head unit. And take loads of photos so you know where things are
![]() Click image to enlarge ![]() Click image to enlarge |
Yeah I bought some 3mm leds worth resistors to make them work with 12V. Then detached the original green LEDs and soldered in the blue ones. Not much room in som of the switches so some internal plastic had to be removed. But I’m happy with them and they look lovely. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Roy,
Where did you get your Dials and LED computer set up? DIY or from one of the usual suspects? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Dials?! The blue circles? If so then they’re just the originals painted blue.
The little computer is an ultra gauge unit built into the binnacle. Again DIY 👍 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Hi Roy
How complex is the ultra gauge install to do please? ![]() 2008 SVX 90 2000 XS TD5 90 |
