Home > In Car Electronics > My Double din install has started (no radio yet...)
Stacey007
OK so having had the double din kit for around 2 years decided I should actually have a go at fitting Smile
Firstly I'm glad I bought a cheap single din take off dash part when I did as cutting the dashboard and cutting the heater matrix stuff off was a bit Shocked Shocked
So before hand survey the parts
Clipping the heater surround off was fun (not) very delicate and I found removing the black glued tabs that hold it in place the best. Just plod away slowly to make sure you don't mark the bits you see on other side.
Done Thumbs Up
Then masked off the single din dashboard and started to cut using a stanley blade, slowly going over and over the same score line.
Have to say would not be happy doing my current surround, as a one shot deal so I was lucky to have the spare. It all is fine in the end but means I can get this ready without having my dash in bits.
Next I have to find a headunit Thumbs Up
I'm also looking at what would go in this gap its approx 50mm 51mm and it does come with a blank so I don't have to put anything?
Will I have to cut the wires to extend switches? Big Cry hope not.....
More to follow
Post #695653 23rd Mar 2018 11:34am
discomog
You've inadvertently convinced me to go for a flip out single din Embarassed Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #695658 23rd Mar 2018 11:43am
Stacey007
^ It's not TOO bad, just take your time doing it,
I did think about a single din but when your using them they hide the buttons and the double din imho looks more up to date?
Thumbs Up
Post #695665 23rd Mar 2018 12:10pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Unfortunately you have to extend at least 1 switch. The left top one.
In the round hole i put the Check tempIII
 a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695668 23rd Mar 2018 12:19pm
Roy5695
I cut the circle off mine. Shaped the edge to match and then painted it. 👍
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #695791 23rd Mar 2018 10:55pm
nihwrd
I didn't have to extend of any my looms, but it is tight. Don't forget to trim the corner on the clock.
I've got nothing in the circular hole (yet).
Nick
Post #699219 7th Apr 2018 5:24pm
dgardel
Italy
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #699501 8th Apr 2018 10:00pm
Looks nicer without the circle. 👍🏻 TheThunder Rolls🇬🇧🇺🇸
Post #699504 8th Apr 2018 10:11pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Roy, Did you change the leds in the switches or did you find some other way of changing the colour? I’ve been wanting to change mine to red to match the rest of my dials and back lights, but as always never got got round to doing anything about it yet.
Post #699598 9th Apr 2018 3:26pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Roy5695 wrote:
Another little project I’ve wanted to do to set mine apart from the rest.
Blue back lighting Thumbs Up
http://www.defender2.net/forum/topic30623-60.html Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #700105 10th Apr 2018 10:27pm
Beeder
I had to extend three switch’s, don’t forget you have to remove the metal bracket in the dash and push the plastic heating duct back a little if your using a pioneer head unit. And take loads of photos so you know where things are
Post #701925 19th Apr 2018 9:09pm
Roy5695
Yeah I bought some 3mm leds worth resistors to make them work with 12V. Then detached the original green LEDs and soldered in the blue ones. Not much room in som of the switches so some internal plastic had to be removed. But I’m happy with them and they look lovely. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #701932 19th Apr 2018 9:51pm
Grenadier
Roy,
Where did you get your Dials and LED computer set up? DIY or from one of the usual suspects? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #701988 20th Apr 2018 5:25pm
Roy5695
Dials?! The blue circles? If so then they’re just the originals painted blue.
The little computer is an ultra gauge unit built into the binnacle. Again DIY 👍 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #702009 20th Apr 2018 7:05pm
Sulisuli
Hi Roy
How complex is the ultra gauge install to do please? Very Happy 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #702020 20th Apr 2018 7:43pm
