![]() | Home > Puma (Tdci) > Volume Control Valve - Ford part no? |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
Yes please update with the results and improvements in performance or not as the case may be. Not everyone takes time to do this and we are all left hanging!
John. "You are never to old to learn something new" |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Also, why would there be a pump learn on diagnostics, if it didn’t need it?
The VCV is the only electrical part on a high pressure pump, other than a temp sensor, there is nothing else to learn, So nothing else would benefit. ![]() Wanted, Forward Control Anything considered. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
The ECM will progressively and with time calibrate itself adaptively even if you don't carry out a manual pump recalibration after changing the VCV. However the time that this takes increases with mileage and therefore it may take longer for a high mileage vehicle to reach optimum performance than a low mileage vehicle.
The reason for this strategy (which was explained to me by a senior LR Tech in whom I have a lot of confidence) is to avoid the need to carry out pump and injector learn operations on new vehicles - the vehicle does it itself and, as it runs in, adapts continuously. As the mileage increases the rate at which variables associated with the engine running change slows down, so it is no longer necessary or appropriate for self-calibration to occur at the same rate. I have on occasions before now changed my VCV and either not recalibrated or more often not successfully recalibrated (some tools are flakey doing this) and the vehicle has always run better after the change anyway and always sorted itself out in due course. It is necessary (if it bothers you) to clear manually the "pump recalibration not completed" stored DTC. It is intersting and supportive of this theory that eventually this DTC will stay cleared even if no manual recalibration is carried out. It also used to be rumoured that there was a finite number of times that this operation could be carried out before a new ECM was required (the suggestion was that the new calibration settings did not over-write the old, but were stored elsewhere in the unit's ROM), however this seems not to be the case. I have met several vehicle which have had many recalibration cycles carried out, and have neither met not heard of one which has failed to to insufficient free memory. I think therefore that there is no truth in this rumour. |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
Thank you Blackwolf.
I might try and change mine in the summer. Hopefully it i can do it... Fabio |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4253 ![]() ![]() ![]() |
Black wolf - thanks for that useful info. While we have your attention can you shed any light on the conditions required to force a pump learn and what should then happen, if anything. I have a Nanocom which has the ability to do a pump learn. Having changed my VCV the car ran ok. I then used the Nanocom, but nothing obviously happened when I pressed the learn “button” and the car drove exactly the same afterwards. I am not convinced anything actually happened, but not sure how I would know. 2007 110 TDCi Station Wagon XS
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4760 ![]() ![]() |
Had the VCV done this morning. It was very easy once you removed the manifold. Did'nt fancy tackling this so I went to the independent. Anyway my big fear in removing the manifold was tearing a gasket. No worries here as it is a number of gaskets both in the manifold and in the block. Anyway back to the VCV. No learning and on the 40 mile drive home it was quieter and engine seemed more responsive. I'll update over the next few days.
So if you want to do this yourself, go ahead but remove the manifold. Whole thing takes less than one hour. I was there and assisted and got the lowdown. Some of the gaskets on the manifold had oil on them. This explains the oil leak that the maindealer insisted was the injector seals. I didn't agree but thought they knew better. They didn't and the oil is being forced out between the manifold and the block. We cleaned the gaskets and refitted everything with new gaskets on order. With the manifold off I was amazed to see how much crude had built up. Back to the 2 stroke me thinks. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 562 ![]() ![]() ![]() |
I meant to give it a try, but I can't even manage to unplug the thing! I can't feel my fingers anymore and the plug won't budge!
![]() How does that plug on the VCV come off? Pull? Press? Cheers! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
I find it is easier to unplug the wires when you have removed the bolts that hold the vcv in place. You can then get at the plug easily
Cheers, will try that!
![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Bit of electronic contact cleaner to get in to the cracks and free up any age old dirt? Solved the bowel problem, working on the consonants...
Quick follow up, job done!
![]() As for the result, tickover is very stable now, the engine is not hunting anymore and overall it feels smoother. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
kirk Member Since: 08 Dec 2012 Location: Abu Dhabi, UAE Posts: 28 ![]() ![]() ![]() |
Help, Please!
![]() With loss of power and symptoms similar to a bad Variable Control Valve, I dove in to change it. After removing the bolts/valve and replacing the valve and the easiest of the two bolts, I dropped ![]() ![]() I went to a local hardware to find a replacement bolt. I purchased a 6mm with an hex/allen head in two lengths in stainless. I also purchased a similar size/length, but in Unified National Coarse (UNC) thread standard. I will reluctantly remove the one bolt I managed to seat properly to test it against the bolts I purchased at the hardware, but before I fasten the new bolt and for added certainty, I thought I would check with the community...Which bolt size fits? Here is a photo of the bolts (UNC on left and metric on right) from the hardware store: ![]() Click image to enlarge |
WhathaveIdone! Member Since: 04 Feb 2016 Location: Sakhalin Island Posts: 27 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Happened to have one lying around. Thread pitch is 1.0mm. My recollection is that these bolts were extremely tight to break out. Not sure i would recommend stainless steel replacements as the strength is likely to be significantly less than the standard grade 12.9 fastener and also it is prone to galling. |
Awesome - thank you so much! Another reason to love this board.
Sakhalin Island? Always wanted to see the sakhalin taimen - some day... thanks again for your help. Kirk |
