![]() | Home > Puma (Tdci) > Volume Control Valve - Ford part no? |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Many thanks for your reply Blackwolf. I am thinking to change the vcv too. Only problem for me is to do the pilot learning as i doubt whether there are any mechanics who can do this for me in this part of the world. Can i run the car without pilot correction after vcv replcement with no halm?
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
If your VCV is faulty the learning procedures for it (in it's original state) are already off
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
It wasn't the seller that advised me, it was a friend who works on nothing but Transits and they get as many come back in for the sensor after the VCV that they always advise to change both, saves two visits! |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
I have managed to get a VCV on order from UKDieselParts.com for £65 incl VAT and delivery and 1 year warranty. They seem to have a good reputation, I will find out soon won't I? Unless the valve is widely out I cannot see how it would not calibrate. My understanding is the valve opening is controlled from a Pulse Width modulated signal from the ECM, so it is proportionally controlled. So the calibration is all about how far it does open for a certain pulse width signal by measuring the output of the high pressure pump and the results are stored back in the ECM. From what I read there is production tolerance that is not precisely controllable hence the need to characterise the valve with the high pressure pump as a pair. I'm not certain I need a new pressure sensor in the end of the high pressure rail, the existing one seems to be generating sensible pressure values according to the diagnostics but I guess these could be some way out of calibration. Thanks for all your help on this, Ill update when I have more results to share. John (aka b4lamb) "You are never to old to learn something new" |
Hi you best read this thread which gives details of the common symptoms. Home > Puma TDCi > Eratic Idle especially when cold John "You are never to old to learn something new" |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
What is the hex size? I tried 3,5 and 4 mm 3,5 is to small, 4 mm seems to big. How did you get a wrench there I tried various small (Snap-on) tools but I cannot go there due to cables and pipes. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Just checked the one I have kicking about and they are 5mm 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
thank you!
No, 5 mm will not fit even 4 mm is slightly to big..
Is it in a 2.4 as tight as in a 2.2? Non of the tinny Snap-on tools will fit, only a long hex key (presuming I have the right size) will do the trick. Otherwise I have to remove the inlet manifold completely. ![]() ![]() Click image to enlarge This is a long hex key in 4 mm that is to big in size.. ![]() Click image to enlarge Hardly any space available (and I have removed some tyraps already. |
Ian, It is quite possible the thread size is 5mm. But what hex socket will fit in? |
The one i have fitted to a spare pump
Is 5mm hex. It is easier to take inlet manifold off, and a simple job. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Parhaps simple but a lot of work, for only a 2 screw sensor...
There is a bracket above the last bulkhead side bold that holds the inletmanifold. I cannot access the bolt ... grr.. Think I have to bleed the heater and remove the hoses to access the bottom of the inlet. Or is it secured with clips? At the rear of the inlet manifold there is a tube secured with bolts too. This is going to take some time... Anyone else faced the same problems? It looked so easy... swopping a sensor.. |
double post..
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
What tools are you using fir the pilot learn? What is envolved with that?
I'm assuming if you have a tuned map, that needs to be changed back to standard map first. Then proceed onto VCV change then the pilot learn, is that correct? It possible combined with my other thread as Ian suggested that this might be my issue too, although just starting to be at least. Are most of the issues related to engine cold and after starting or issues at all temps? Mines fine when warm but a bit temperamental when very cold. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
