![]() | Home > Maintenance & Modifications > Dinitrol Treatment - Nth Yorks |
flatfrog Member Since: 04 Mar 2018 Location: East Yorkshire Posts: 5 ![]() ![]() |
Can anyone recommend a Dinitrol Application garage near York? Thanks
Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190 ![]() |
Try DPG Defenders at Kirbymoorside, I've got mine booked in for a treatment in June. Time is precious, waste it wisely...
Defender 90 D200 |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Flat frog it’s also worth using the search button here to do some more research
![]() 2008 SVX 90 2000 XS TD5 90 |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Flatdog uk in Gainsborough are superb and not that far away 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
As a suggestion, you may or may not believe it's an option but do consider the possibility of doing it yourself.
You can do it yourself in good weather for no more than around £150 max and a bit of free time, compared to hundreds of £'s to be done. If you don't have a compressor as I didn't, you could use Aerosol as I did with excellent results and save the money for other curios, mods or accessories instead. ![]() ![]() Just a suggestion, but of course if you do need it doing for you or not enough spare time then it's not an option. ![]() ⛽️🛢️⚙️🧰💪 |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
Alpine Restoration sin Halifax
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1044 ![]() ![]() ![]() |
There's Trek Overland in Nawton. I've not used them for a while, but had good service on my Td5.
