Home > Maintenance & Modifications > Dinitrol Treatment - Nth Yorks
flatfrog
Can anyone recommend a Dinitrol Application garage near York? Thanks
Post #699466 8th Apr 2018 8:08pm
Sulisuli
If you google Dinitrol their website lists approved application centres, this will be a good starting point for you 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #699470 8th Apr 2018 8:18pm
Blacksheep
Try DPG Defenders at Kirbymoorside, I've got mine booked in for a treatment in June. Time is precious, waste it wisely...
Defender 90 D200
Post #699481 8th Apr 2018 8:38pm
Sulisuli
Flat frog itโ€™s also worth using the search button here to do some more research Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #699485 8th Apr 2018 8:59pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Flatdog uk in Gainsborough are superb and not that far away 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #699487 8th Apr 2018 9:13pm
As a suggestion, you may or may not believe it's an option but do consider the possibility of doing it yourself.
You can do it yourself in good weather for no more than around ยฃ150 max and a bit of free time, compared to hundreds of ยฃ's to be done.
If you don't have a compressor as I didn't, you could use Aerosol as I did with excellent results and save the money for other curios, mods or accessories instead. Mr. Green Rolling with laughter
Just a suggestion, but of course if you do need it doing for you or not enough spare time then it's not an option.
Thumbs Up $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #699493 8th Apr 2018 9:31pm
AJC
Alpine Restoration sin Halifax
Post #699601 9th Apr 2018 3:33pm
AMBxx
There's Trek Overland in Nawton. I've not used them for a while, but had good service on my Td5.
Post #699817 10th Apr 2018 10:45am
