Home > Puma (Tdci) > Parrot MKi9200 Bluetooth Handsfree Kit V3
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Considering buying one of these for my 2012 Puma 110 USW XS as they get good reviews as a hands-free and music playing device. Does anyone have experience of fitting and using one? Do all the extra looms and electronic box supplied with the kit fit into the space behind the standard LR head unit? Is there any need to buy any additional looms, adapters to connect it to the Puma? Bow down Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #699175 7th Apr 2018 2:57pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I have it in mine and yes it's a doddle to fit and no need for additional adapters as it's a standard ISO connection
The blue box sits either left or right of the Headunit, plenty of space for it in the dash. Simply plug your current ISO connections into from the Landy and plug the ISO connection from the blue box into your Headunit.
Microphone can be wired down the right hand side of the dash into the footwell and up into the fuse box area, across the footwell and up the pillar into the headlining...i actually mounted mine on the sun visor, you do see a small cable but that's ok with me.
If you have the screen as well, you can mount this above the headunit and the cable will go between the facia panels underneath the clock when you click it all back in place ( this requires you to remove the facia panel first, but you can re route the cable anywhere if you like.
Hope that helps Thumbs Up
Post #699187 7th Apr 2018 4:01pm
Sammyboy
Thanks Badger110 that is very helpful. Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #699194 7th Apr 2018 4:29pm
Sammyboy
Hi Badger 110
I see from the installation instructions that there are 3 options as to which to connect the 'mute' wire to; which one did you choose 1, 2 or 3??
I have also noted that there are 2 versions of this kit; the v2 and v3. Which one have you got?
Cheers Bow down Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #705443 5th May 2018 1:33pm
BT playback can be extremely useful to use and more future proof than cabling.
It should also let you use your phone or iPad as your HU and control device and no built in HU can really compete with that.
Steve Mead Designs had a nice in dash iPad device build the other day I saw.
There are also stand alone BT devices you can run with RCA outputs to an external amp, which can run a full system.
Of course you don't have the BT then though.
Lots of possibility. Thumbs Up No Guts, No Glory.
Post #705448 5th May 2018 2:42pm
Sammyboy
Bought and fitted last weekend, what a brilliant system Thumbs Up Thumbs Up Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #707385 15th May 2018 7:34pm
