Home > For Sale & Wanted > [Wanted] Hp22 Gear change operating lever and trunnion |
pepethekingprawn Member Since: 12 Jan 2016 Location: Lancashire Posts: 54 |
I have a zf4hp22 that has failed forward drive, may have some bits you need?
31st Mar 2018 8:22pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2248 |
Pepethekingprawn,
I do have a bit of a shopping list in addition to the above parts I'm also looking for the transfer box operating parts for an LT230 if yours is from a Disco. Cheers Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
31st Mar 2018 10:14pm |
Additionally I'm also looking for the bracket to which the block on the shifter cable bolts.
1st Apr 2018 10:14am |
I know I have the cable bracket and lever arm, not sure if I still have the transfer lever and mounting bracket as it may have been used for something else but I'll have a look and let you know. Will be tomorrow though.
1st Apr 2018 11:54am |
That's cool, tomorrow is fine 😊
1st Apr 2018 12:26pm |
What I actually need IIRC is just the straight disco diff lock operating bar and the discovery type bracket that the lever turret bolts to if that helps (different to Range Rover).
1st Apr 2018 6:30pm |
