![]() | Home > For Sale & Wanted > [Wanted] Hp22 Gear change operating lever and trunnion |
pepethekingprawn Member Since: 12 Jan 2016 Location: Lancashire Posts: 54 ![]() ![]() ![]() |
I have a zf4hp22 that has failed forward drive, may have some bits you need?
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2279 ![]() ![]() ![]() |
Pepethekingprawn,
I do have a bit of a shopping list in addition to the above parts ![]() Cheers Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Additionally I'm also looking for the bracket to which the block on the shifter cable bolts.
I know I have the cable bracket and lever arm, not sure if I still have the transfer lever and mounting bracket as it may have been used for something else but I'll have a look and let you know. Will be tomorrow though.
That's cool, tomorrow is fine 😊
What I actually need IIRC is just the straight disco diff lock operating bar and the discovery type bracket that the lever turret bolts to if that helps (different to Range Rover).
