![]() | Home > Puma (Tdci) > Tyre squeal on roundabouts |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
I sometimes do that, but Small still hangs on to the spare wheel. Good grip this girl
![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
My 7.50s squeal on hard cornering when I've got them around 35psi, they don't when they're at 40.
Make sure your diff-lock isn't engaged.
That would give you tyre squeal on longish turns. ![]() |
ParabolicSwivel Member Since: 13 Nov 2013 Location: Hertfordshire Posts: 42 ![]() |
Success! 40psi seems to have done the trick - threw it around a few roundabouts this morning with no complaints from the tyres!
![]() Had previously been keeping them round 30-ish - that’s quite a big difference so might experiment a little. |
I used to keep them about 33 but the tyre life was a bit pants.
I know if you run them at 50-60 the ride is horrible when empty, and 40-45 works for me. Depends on what I'm putting in etc. If I know I've got lots of offroad stuff coming up with some slow on road, then I'll got back to 30-35. If I've got some difficult off road with no road, then below 30. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
The only time I have managed to get the fronts to squeal on any 4x4 was when an in experienced mechanic on completion of a service failed to take the diff lock out. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
