Home > Puma (Tdci) > Tyre squeal on roundabouts
Page 2 of 2 <12
Swine&Small
I sometimes do that, but Small still hangs on to the spare wheel. Good grip this girl Rolling with laughter 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #696753 28th Mar 2018 5:03pm
Cupboard
My 7.50s squeal on hard cornering when I've got them around 35psi, they don't when they're at 40.
Post #696762 28th Mar 2018 5:41pm
Laurie
Make sure your diff-lock isn't engaged.
That would give you tyre squeal on longish turns.
Post #696794 28th Mar 2018 7:23pm
custom90steve wrote:
"How times change. I used to frequent performance car forums and the talk of only 8 or 10k miles on a set of tyres, and was that a problem etc etc. 25k on a set of tyres is imho fine, the mind boggles how anyone drives to get 45-50k on one set! "
Isn't the real question what is the design life of the tyre and then measuring what your variance to that is?
A tyre that is designed to give high levels of grip on a performance vehicle will trade longevity, as it will be a relatively soft compound; a general all terrain tyre will not work quite so hard so so will have a longer life.
Post #696879 29th Mar 2018 7:01am
ParabolicSwivel
Success! 40psi seems to have done the trick - threw it around a few roundabouts this morning with no complaints from the tyres! Smile
Had previously been keeping them round 30-ish - that’s quite a big difference so might experiment a little.
Post #697176 30th Mar 2018 12:46pm
Cupboard
I used to keep them about 33 but the tyre life was a bit pants.
I know if you run them at 50-60 the ride is horrible when empty, and 40-45 works for me. Depends on what I'm putting in etc.
If I know I've got lots of offroad stuff coming up with some slow on road, then I'll got back to 30-35. If I've got some difficult off road with no road, then below 30.
Post #697180 30th Mar 2018 12:59pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
The only time I have managed to get the fronts to squeal on any 4x4 was when an in experienced mechanic on completion of a service failed to take the diff lock out. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #697385 31st Mar 2018 10:08am
Page 2 of 2 <12
