Home > Technical > Electric window switch |
The problem is most likely to be a broken wire in the rubber between the post and door. Ray
23rd Mar 2018 11:04pm |
Edd1982 Member Since: 02 Mar 2018 Location: West Yorkshire Posts: 13 |
I must confess I did have a little nosy at that, but I just wanted to swap the switches over to rule that out.
Any idea which wire it's likely to be, and what's the best way of checking it? Cheers |
23rd Mar 2018 11:09pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
I’am currently fixing it
First take off doorcard. Then remove rubber sleeve from door fixing and pillar fixing. Then you can wiggle the sleeve back and front to Check all the wiring. In my Case the red one was broken and the Blue one had a tear. So replacing both. If you want photo’s let me know. a defender from 1984 pretending to be a puma with a touch of Range Rover |
24th Mar 2018 6:17am |
That's brilliant, thanks for that 👍
24th Mar 2018 8:38am |
Second Photo is Just an overview. In the first Photo i wiggled the sleeve upwards. To expose half of the wires to inspect them. Then downwards to inspect the other half. The red and Blue wire are both 2 mm2 wires. The wires used by LR are too stiff so get a good quality flexible wire. I run the new wire through the sleeve and solder them. Did the first one you can see on the left.
Click image to enlarge Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
24th Mar 2018 8:54am |
Thanks for those. Glad I left the door card off 😀
24th Mar 2018 9:03am |
Haha a defender from 1984 pretending to be a puma with a touch of Range Rover
24th Mar 2018 9:06am |
Photo 1 there’s a connector in the pillar. And Photo 2 everything works. Just have to tidy up everything!
24th Mar 2018 2:09pm |
I now have a working window. It was the red and blue wires that had broken. Soldered them back together and jobs a good en. Also manged to sort my door so it doesn't bounce open when I try to shut it
Thanks for the assistance guys |
24th Mar 2018 7:04pm |
Glad it's sorted Ray
24th Mar 2018 7:46pm |
