Home > Technical > Electric window switch
Edd1982
My drivers window has stopped working.
Sorry if this is a silly question but how do remove the electric window switches from the facia? I've taken the radio out, and thought I could just push them out from the back.
Post #695790 23rd Mar 2018 10:51pm
mk1collector
The problem is most likely to be a broken wire in the rubber between the post and door. Ray
My build thread
Post #695792 23rd Mar 2018 11:04pm
Edd1982
I must confess I did have a little nosy at that, but I just wanted to swap the switches over to rule that out.
Any idea which wire it's likely to be, and what's the best way of checking it?
Post #695793 23rd Mar 2018 11:09pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I’am currently fixing it Laughing
First take off doorcard. Then remove rubber sleeve from door fixing and pillar fixing. Then you can wiggle the sleeve back and front to Check all the wiring. In my Case the red one was broken and the Blue one had a tear. So replacing both. If you want photo’s let me know. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695815 24th Mar 2018 6:17am
Edd1982
That's brilliant, thanks for that 👍
Post #695835 24th Mar 2018 8:38am
Tdi4
Second Photo is Just an overview. In the first Photo i wiggled the sleeve upwards. To expose half of the wires to inspect them. Then downwards to inspect the other half. The red and Blue wire are both 2 mm2 wires. The wires used by LR are too stiff so get a good quality flexible wire. I run the new wire through the sleeve and solder them. Did the first one you can see on the left.
Post #695839 24th Mar 2018 8:54am
Edd1982
Thanks for those. Glad I left the door card off 😀
Post #695842 24th Mar 2018 9:03am
Tdi4
Haha Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695843 24th Mar 2018 9:06am
Tdi4
Photo 1 there’s a connector in the pillar. And Photo 2 everything works. Just have to tidy up everything!
Post #695891 24th Mar 2018 2:09pm
Edd1982
I now have a working window. It was the red and blue wires that had broken. Soldered them back together and jobs a good en. Also manged to sort my door so it doesn't bounce open when I try to shut it
Thanks for the assistance guys Thumbs Up
Post #695947 24th Mar 2018 7:04pm
mk1collector
Glad it's sorted Thumbs Up Ray
My build thread
Post #695957 24th Mar 2018 7:46pm
