Home > Puma (Tdci) > Studs exhaust manifold to turbo keep coming loose |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
In the next couple of weeks am going to a workshop to do some maintenance. And I want to tackle this problem once and for all.
The problem is that the studs are coming loose mainly in the summer and on load (caravan, 4 kids, mountains etc). Not the bolts but the studs. What have I done so far. 1. Fitted the thick spacer (bought it at alive) 2. Got bigger studs m10 All with no succes. Any ideas? I run an alive remap, with a bespoke turbo, allisport radiator, allisport intercooler, decat, 100 mm air intake a defender from 1984 pretending to be a puma with a touch of Range Rover |
20th Mar 2018 8:31am |
Low-Range Member Since: 30 Sep 2016 Location: BC Posts: 41 |
You can buy a compound that you put on the threads before you tighten them. http://www.all-spec.com/UserFiles/Images/P..._WebXL.jpg
20th Mar 2018 8:38pm |
Thnx!
But is it sufficient temperature resistant? As far as I can see ir’s Rated > 300 degrees. But the exhaust manifold will reach > 800 degrees? a defender from 1984 pretending to be a puma with a touch of Range Rover |
20th Mar 2018 8:50pm |
Different products have different ranges.. https://pilotshq.com/loctite-superflex-red...11054.html
20th Mar 2018 8:56pm |
Correct but this product is rated to 315 degrees. I haven’t found a product which can withstand the temperatures of a exhaust manifold. a defender from 1984 pretending to be a puma with a touch of Range Rover
20th Mar 2018 9:29pm |
Thnx Blackwolf,
Sorry but I can’t figure out where to put the spacer. Stud goes into manifold and then??? a defender from 1984 pretending to be a puma with a touch of Range Rover |
21st Mar 2018 5:54am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17359 |
Longer stud into manifold, turbo onto studs, spacer onto stud, nut onto spacer.
A very similar thing is often done on where TD5 exhaust manifolds bolt to the head to prevent the studs from breaking for similar reasons. |
21st Mar 2018 8:37am |
Okay will try that (as well ).
But I'am trying to understand this solution, if it works I don't need to understand it. But what is different? The bolt is put on tight but still the stud comes loose. What is the function then of the washer? a defender from 1984 pretending to be a puma with a touch of Range Rover |
21st Mar 2018 9:18am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
I have blocks on my Td5, it's worked for the last 5 years
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Mar 2018 9:35am |
Hi Grafty,
Are those stretch bolts? a defender from 1984 pretending to be a puma with a touch of Range Rover |
21st Mar 2018 9:44am |
No just standard 8.8 2002 90 Td5 Station Wagon
21st Mar 2018 12:25pm |
Hi grafty
Then I didn’t understand you correctly. Another Dutch guy trying to speak English What are blocks? I ‘ve looked at the picture and I didn’t see anything else than the bolts? a defender from 1984 pretending to be a puma with a touch of Range Rover |
21st Mar 2018 4:04pm |
There are cylindrical metal blocks which the bolts pass through before the manifold face
I'll edit the picture to explain better 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Mar 2018 9:06pm |
The section in red is the block which expands to keep tension on the bolts
21st Mar 2018 9:47pm |
