Home > Puma (Tdci) > Rattling gear knob . . . .
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Just come back from dartmoor, 90 went ok but the speed limiter did my head in, will have to look on how to sort that little issue out, second my gear stick rattles pretty bad when you excellerate from lol ish revs up to 2600 ish in 6th, anyone know a solution? Smile
Post #69387 2nd May 2011 7:58pm
Jammer600
Can't find anything about limiter removal????
Post #69389 2nd May 2011 8:15pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Speed limiter is controlled by ECU - Remap is the only way to remove it. Sad
Post #69404 2nd May 2011 9:13pm
Fifth Horseman
Check the damper weights at the base of the gearstick, these can become loose, use something like a cable tie to wedge them in place.
It could also be wear of the lever balljoint into the gearbox, bit of a faff to change and about �80 part no. TSC500020 this will also tighten the gear change up if it's a bit loose.
Just done this on my vehicle.
Post #69408 2nd May 2011 9:44pm
Jammer600
What do you just pull back the gaiter and it's under there? It has got 50 tho on the clock so could be wear but I'll check
Post #69414 2nd May 2011 10:09pm
Fifth Horseman
Yes, the section with the weights is just under the gaiter.
To remove the lever end, there are two clips at its base pull these out slightly and the lever should come off.
Post #69427 3rd May 2011 5:33am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Some good info there Horseman Thumbs Up Going to check mine to see if i can stop it rattling. 130 crew cab
98 V8 Disco
Post #69489 3rd May 2011 1:20pm
Jammer600
Just sorted mine out, pulled gaiter up from bottom, took gear stick off, two sprung clips which holds it so that was easy, gave it a shake and the weights on the bottom were loose so I just packed them out and is good as new, little tip if you're guna do this don't pull gaiter up from the bottom, slide it down off the bottom of the stick, un clip and check, saves faffing about trying to get the gaiter back on properly!!
Post #69682 4th May 2011 8:10pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
I was trying to do the same last evening, as you said by pulling the gaiter down. But it takes a lot of effort to keep it down enough to be able to unclip the stick. Probably i need a mate to help me Smile This will be my next weekend's project.
ciao!
Post #69739 5th May 2011 10:31am
parktag
Well, i checked mine and it seems like the plastic balljoint is a little loose so i'll have to change it to stop the rattling. What really suprised me was the difference in noise levels with the carpet off. My clutch has always clunked but it's always been very quiet while driving but after removing the carpet it sounded bloody awful, as though the gearbox was about to explode at any time. anyway with the carpet back on it sounds fine again. Do you think the sound insulation might be hiding the fact that my clutch is doing more dammage than i first thought? It really did sound bad. 130 crew cab
98 V8 Disco
Post #69829 5th May 2011 6:20pm
CyberCharlie
10 minutes! 10 minutes to fix the annoying rattling. The difference was made by a pair of loving hands (my girlfriend's) that helped me to pull down the gaiter. Then... unclipped the stick, checked the rattling (weighs got a bit loose), pushed a bit of cardboard between the weighs and the supporting structure, poured a drop of glue to keep everything in place for good, pushed the stick in the gaiter and clipped it back.
Ding dong, the rattling is gone Smile
Post #70052 7th May 2011 7:06pm
bhayes
South Africa 2009 Defender 90 Puma 2.4 SW Keswick Green
Thanks Horseman - I will give that a try
Post #89094 14th Sep 2011 3:00pm
